It is currently Mon Jul 14, 2025 12:35 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: 6 speed box
PostPosted: Sat Aug 14, 2010 11:51 pm
this is some pics of the basic set-up of the 6 speed squential shift gear set in a mini case
1st gear is on the left of pic. it is quite a bit bigger than std mini.
the end is milled to a depth of 25mm from the original face and a hole opened up for the shift drum to fit in. the main shaft is fitted into original bearing holes. a new 25mm plate with bearing holes is bored to suit shaft center dist and is then welded into position.
just a little of clearance with 1st gear, but piece welded over to blend into case
the bike mainshaft with spline ground onto the end to take mini pinion
plenty of room underneath main shaft for the new oil pick up position
the selector drum sits roughly in this position.
the reverse gear is mounted to the main and input shafts and is engaged by a sliding idler gear
www.minisprintgt.com
PostPosted: Sat Aug 14, 2010 11:58 pm
what are those gear sets out of, or have they been machined to suit.
what kind of cost to build something like this 10K plus.
PostPosted: Sun Aug 15, 2010 12:05 am
the gear set is a std honda cbr 1100 RR bike. 1st is 2.75:1 and 6th is 1.1:1
the honda vfr 800 [and the new 1200 bike] run the same shafts and center dist etc. the gears are inter-changable but they are 1st 2.89:1 and 6th is .89:1 better for a road car
price????????????????? probably about 1/3 of what you reckon. do not know at this stage until it is all finished
PostPosted: Sun Aug 15, 2010 12:29 am
my other question is how many hours.
racking yer brain trying to make it work in your head
working those machines to get it to work in your car
and must say, suitably impressed, and keen/intrigued to see/hear it running.
PostPosted: Sun Aug 15, 2010 9:50 am
GO FOR IT DAVID
PostPosted: Sun Aug 15, 2010 10:06 am
and is the 6th gear make the mini a lot quieter?? ie 3000rpm at 100km-h?
PostPosted: Sun Aug 15, 2010 10:08 am
and what sort of power can it handle? I was thinking of a 5 speed box, but this could be quite exciting. would it handle a Downton 1310cc with stage 3 head and twin 1.5" Sus??
PostPosted: Sun Aug 15, 2010 10:54 am
shotgun for the prototype! :lol:
mooo, I'm a pig!
PostPosted: Sun Aug 15, 2010 11:43 am
Interested... Looks great. :)
- Simon -
PostPosted: Sun Aug 15, 2010 12:19 pm
I see why you're not going to make one for anyone other than yourself... complex bit of gear
I love the way shift drums work, beautifully simple
PostPosted: Sun Aug 15, 2010 12:24 pm
Mods rock!
Considering what the gear set came from, anything any A series could put out.
PostPosted: Sun Aug 15, 2010 12:44 pm
Awesome work, as usual. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Aug 15, 2010 7:31 pm
Rod or remote change box?
And how is the new gears selected, is it through a std positioned gear stick or is it flappy paddle or what?
PostPosted: Sun Aug 15, 2010 8:10 pm
Surely it'd be a sequential stick.
It's the closes to the bike's foot peg arrangement.
PostPosted: Sun Aug 15, 2010 9:22 pm
that is sooo awesome!!!!
the gears are straight cut?? i would think it's going to defeat the point anyways.
good for a race car though kick ass!
