It is currently Sun Jun 29, 2025 11:49 am
Post new topic Reply to topic  [ 207 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 14  Next
PostPosted: Mon Aug 02, 2010 1:26 am
when possible.
could you post details on the oil relocation kit - where, what and how much?
please.....
thanks!!
Rob.
PostPosted: Tue Aug 10, 2010 9:52 pm
Still haven't found one that will have a connection for oil feed to the turbo. There are plenty around (search perma-cool, jardine, derale)... just wondering if its worth getting one of the generic ones and putting a tee for the turbo feed - just worried about lack of oil pressure then though. Anyones thoughts?
Answer the Question....
BUT always Question the Answer
PostPosted: Tue Aug 10, 2010 10:19 pm
Ha? The factory oil filter relocator has the outlet for the feed line for the turbo.
Now the obvious question is have you removed the whole relocator to fit your relocator or are you just going to put your relocator where the oil filter would go?
PostPosted: Tue Aug 10, 2010 10:21 pm
amos wrote:
And yet another q for all the knowledgeable people around here... I'm looking into remote oil filter kits... What is the hole on the top right for?? Oil pressure? Oil temp sensor??
Guess i need to know what i need on the remote kit before i commit to buying one...
Fairly confident that is your feed line for the turbo.
PostPosted: Tue Aug 10, 2010 10:24 pm
Found one
This is off the starlet I built.
The red anodised speedflow fitting on the bottom right hand corner, thats your feed for the turbo.
I think Dan (minimetoy) removed the factory oil filter relocator and got his pressure feed for the turbo from the oil pressure switch.
PostPosted: Tue Aug 10, 2010 10:40 pm
There....
http://www.ausmini.com/forums/viewtopic.php?t=18264&postdays=0&postorder=asc&start=150
PostPosted: Tue Aug 17, 2010 7:21 pm
Cheers JC.. the plan is to remove the pictured part completely and put in a relocating boss. There isn't any room for the std one with my installation unfortunately..
PostPosted: Tue Aug 31, 2010 11:38 pm
What are peoples thoughts on running a single after market fuel pump in the engine bay somewhere and having no submersible pump in the fuel tank? I'm thinking a new fuel cell and pump is all....
Do you think priming will be an issue? Any other issues anyone can see with a setup like this?
PostPosted: Wed Sep 01, 2010 9:28 am
I run a single in line pump (VL turbo) from the tank. Its mounted under the back of the car. Don't mount in the engine bay. It will be too noisy plus they are made to push fuel rather than suck.
It runs ok at the moment without a surge tank and lifter pump, but I keep the tank above 1/2.
Previously I let it get down a bit on a long twisty drive and it was starving the pump of fuel. ended up having to replace the pump. :roll: I now have a surge tank on the workbench waiting to be fitted. :wink:
It should be better with a upright saloon tank rather than the long, flat van tank, but put a surge tank in anyway. its cheaper than a new efi fuel pump. :(
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Tue Sep 14, 2010 10:21 pm
Update o'clock....
All seat brackets are complete - view from behind:
How the brackets look when the passenger seat is removed:
Result!
And finished off the idler pulley bracket for the water pump too...
Test fit looks like this (belt for reference only as it's too long and belongs to the alternator):
Bracket without idler:
PostPosted: Wed Sep 15, 2010 1:17 pm
Well done Nick. Unless I've missed it before, it's the first time I've seen an tensioner used for the water pump instead of stretching the belt over the crank & water pump pulleys.
-Alan
PostPosted: Sun Sep 19, 2010 10:19 pm
Got the brackets and tensioner for the alternator finished today, among a few other bits and pieces...
Does anyone know whether putting an after-market air filter and inlet line to the turbo means having to do emissions testing to rego in SA? Don't really have a lot of choice but to re-route the inlet for packaging reasons.
PostPosted: Sun Sep 19, 2010 10:58 pm
as far as i know your allowed 2 induction modifications.
ie: front mount intercooler and pod filter is legal.
so aftermarket airfilter should be fine!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
 Post subject: Oil filter relocation
PostPosted: Tue Sep 21, 2010 9:29 pm
arjay wrote:
when possible.
please.....
thanks!!
Rob.
Just for you :D
Picked up some more goodies today! Oil filter relocation kit.... From earls. Part numbers are 1178ERL (Filter replacement boss) and 2178ERL (Filter mount). You can get cast versions of the same thing (probably a bit cheaper but not as sweet lookin!)..
Now just gotta get busy with the catalogue and work out what fittings i need...
PostPosted: Thu Sep 23, 2010 3:53 pm
amos wrote:
arjay wrote:
when possible.
please.....
thanks!!
Rob.
Just for you :D
How much if you dont mind me asking?
Life's a garden.... Dig It!
Users browsing this forum: No registered users and 25 guests
