It is currently Tue Jul 22, 2025 2:51 am
PostPosted: Thu Sep 02, 2010 10:31 pm
Hi Guys,
So just got my newly rebuilt engine, and have been continually told all these little tricks of the trade, do's and dont's before and after starting the engine, and running in techniques... etc blah blah blah...
I won't list up What I've been told, but if you post up what you suggest/ do, to ensure things don't go wrong... and I'll add to the list of mine, if I haven't already got it :)
Thanks Lockie.
PostPosted: Thu Sep 02, 2010 10:55 pm
You're going to stir up a wasps nest :wink:
PostPosted: Thu Sep 02, 2010 11:06 pm
whys that?
PostPosted: Thu Sep 02, 2010 11:35 pm
Flog it from new! Thats my theory.. If it brakes it has warranty. Plus it will go a lot harder than if you baby it! :D
PostPosted: Thu Sep 02, 2010 11:36 pm
Make sure the motor is in the engine bay right side up. ( oil pump tends to labor on its head)
Canola is not good for running in a new motor.
Make sure motor has Pistons, if pistons are present make sure you cant see them cos if you can you may need a reco head, or you have a bloody big hole in your block( if the latter is true give your engine reco man a smack up side his head cos he is obviously retarded or drunk)
Make sure all spark plugs look like spark plugs not cork bungs( cork bungs smell like red wine)
Make sure you have at least 1 oil leak( most minis have 1) its a good indication oil is where its supposed to be
Use nuts and bolts to hold the motor in the car as string and duct tape just dont work
Put the bonnet back on( if you havnt tripped over it and kinked the buggary out of it)
Look out for wasp nests in and around the engine bay :D :wink:
PostPosted: Thu Sep 02, 2010 11:44 pm
NAV-MAN
My mate asked me once if my rebuilt engine leaked oil, of course i said no as it didnt at the time, he told me to take it back and get one installed.
PostPosted: Thu Sep 02, 2010 11:52 pm
If you have a new cam, remember to run that in on start up. :)
PostPosted: Fri Sep 03, 2010 12:04 am
Just drive it "Normally" if it`s going to be a "Normal" road car
PostPosted: Fri Sep 03, 2010 12:31 am
you mustn't be buying your Canola Oil from KMart ;)
tim
PostPosted: Fri Sep 03, 2010 6:05 am
It's not a normal engine, its been beavfed up, got a fair bit of race gear in it, but its not over the top.. So I would say its a taste of both worlds.. if that makes sense
Owen, yep its a new cam..
PostPosted: Fri Sep 03, 2010 6:25 am
I put the new oil container in a bucket and fill it with hot water, to warm up the oil. Once I have filled the engine with the warm oil I use the hot water in the bucket to fill the radiator, that way on start up you allready have a engine at running temp, easier to tune, rev etc.
Have a Nice Day.
PostPosted: Fri Sep 03, 2010 7:23 am
Never heard of that....but what a good idea particularly in cold weather.
Lockie91 wrote:
whys that?
There was a hot thread on that sometime ago. You must have missed the fun. I'll see if I can find it.
PostPosted: Fri Sep 03, 2010 8:05 am
that was my lucky thread lol.
i just drove mine easy lockie for about 1000km never hit over 80ph.
loaded it up hills never revved it hard at all.
once it hit the 1000km mark i then started to give it a bit more, as in normal driving on the highway 100 or 110 etc
I did not thrash it at all untill 2000km & it's been happy days, engine is perfect inside.
I stripped it to upgrade for the sc12 but it's perfect inside.
PostPosted: Fri Sep 03, 2010 8:47 am
Lockie91 wrote:
whys that?
everyone has a different opionion that contradicts everyone else, and everyone swears by their way.
both sides have merit, but i can tell you how to NOT run in a motor if you want. don't deliver piizzas with a fresh motor. not good
78 Leyland Mini - Prince
PostPosted: Fri Sep 03, 2010 4:01 pm
Nothing to do with Mini's but when I got the engine done up on my 50's Harley, I asked the shop how I should run it in they said "Ride it like you stole it and she'll be fine" :o
