It is currently Wed Jul 23, 2025 9:34 am
PostPosted: Sun Sep 05, 2010 2:11 pm
Hi All,
Going to flush the cooling system in the Mini, never done it before, but doesn't really sound too hard so I figured i'd give it a go.
What coolant do people on here use?
Should i get a premixed one? or mix my own? any advantages / disadvantages?
Thanks
1975 Hairy Lime/White Clubby
PostPosted: Sun Sep 05, 2010 2:25 pm
If you buy premix you are buying coloured water, often with unknown concentration of glycol in it.
I buy Nulon ethylene glycol and mix my own, 20-25% concentration in water is plenty for Australia.
If you want even better, use distilled or de-ionised water instead of from the tap.
PostPosted: Sun Sep 05, 2010 2:50 pm
ive always bought that 500ml bottle of XTRA COOL, brand is Tectoloy.
its a concentrate, mix half the bottle into the radiator, save half the bottle for top ups.
 Post subject: Coolant
PostPosted: Sun Sep 05, 2010 3:02 pm
Toyota make and sell a very good one. It is red in colour. Beats any other brand especially "attackalloy"
"Let us remove your "SHORTS"
PostPosted: Sun Sep 05, 2010 4:22 pm
I use the nulon one. Its cheap, and It does the job.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
 Post subject: Re: Coolant
PostPosted: Sun Sep 05, 2010 6:28 pm
+1 for that, Great coolant 8) and the trendy red color makes a change from green
PostPosted: Sun Sep 05, 2010 6:43 pm
Distilled water and "wetta water".
Engine is as clean as a whistle.
I don't use glycol....it's an antifreeze :shock:
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Sun Sep 05, 2010 6:51 pm
Minimad
Glycol is also an antiboil. It raises the boiling temperature of water significantly. http://en.wikipedia.org/wiki/Ethylene_glycol
PostPosted: Sun Sep 05, 2010 7:11 pm
I use Redline- Water Wetter.Excellent product- It's not cheap though.$30.00 for a 600m bottle.Do a search and read about it.
I also only use distilled water with this product.
PostPosted: Sun Sep 05, 2010 7:24 pm
Castrol.
So I never forget which brand it is I use and risk mixing coolant types.
Not so much of a problem these days I am told, but for a while cheap and expensive coolants would react and turn to gel. Then when enough passages were clogged in the radiator and the car boiled dry, the gel would turn to scale, which was an excellent heat insulate.
The ARE radiators website used to have excellent pages on this coolant mixing problem, and also other pages on stray currents and alumuminium radiators...but some of the links are broken..others are still a good read..
http://www.are.com.au/feat/techtalk/techtalk.htm
PostPosted: Sun Sep 05, 2010 7:30 pm
thanks for all the input :-)
I think i'll get either the nulon or the toyota product you've suggested and some distilled water
PostPosted: Sun Sep 05, 2010 7:32 pm
Lillee wrote:
You need to sort your facts out.
Redline Wetter Water is Glycol based.
http://www.redlineoil.com/Products.aspx?pcid=10
"Superior heat transfer properties compared to glycol-based antifreeze"
I am sure wetter water is a great product, but to me, Glycol is glycol.
I have... Read the water wetter site properly... it is not glycol based...it just compares it to the properties of glycol.....'Satisfies ASTM D2570 and ASTM D1384 corrosion tests for glycol-based antifreezes' and your very nice quote above :wink:
Your right, Glycol is glycol and it needs to raise the the boiling point of water because as a coolant it isn't as good as plain old water :!:
If you want to see a mini motor overheat.. just run it on straight gycol :twisted:
Minimad
PostPosted: Sun Sep 05, 2010 7:52 pm
+ 1 more. I use it in my Toyota. When i have my mini back on the road i'll be using it in that too. Make sure you flush the system with clean water when changing from green to red. I don't think they like each other and shouldn't be mixed.
- Simon -
PostPosted: Sun Sep 05, 2010 8:08 pm
So who makes the Toyota stuff? Because Toyota actually makes very little stuff themselves and uses outside suppliers for nearly everything.
I use Caltex coolant. I know who makes it.
PostPosted: Sun Sep 05, 2010 8:49 pm
Redline Water Wetter here, with Distilled water. Also heard good things about the Toyota coolant as well.
Users browsing this forum: Steam and 87 guests
