It is currently Wed Jul 23, 2025 7:21 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 05, 2010 11:06 pm
To be honest guys, does Wetter Water make that big a difference to temperatures? (that was not a sarcastic question, but a genuine one). Is it noticeably better performance than Glycol?
I find I run too cold in winter as it is...
Lillee - 1969 Morris Mini K
PostPosted: Mon Sep 06, 2010 6:08 pm
I'm taking a guess only...haven't researched it. Water draws/transfer heat better than oils, glycol or other additives. A wetting agent (detergent is a wetting agent)
would eliminate surface tension therefore bubbles would fail quicker
and surface area of the water with the block and head would be greater.
Am I right?
PostPosted: Mon Sep 06, 2010 6:43 pm
as i understand????
with the additive, and less bubbles forming on the surface. Would this mean less cavitation (moving of water in a non uniform way) which slowly damage the water jacket of the block, the radiator and everything else it runs through.
I had this explained to me buy a bloke that works on large gas plants. he said whether its a gas or a liquid, smooth corners and better flow means less cavitation, means longer lasting parts.
http://en.wikipedia.org/wiki/Cavitation
PostPosted: Mon Sep 06, 2010 7:32 pm
i got the Toyota red one too....
the guy at the spare parts counter sold me the concentrate and said they mix it 50/50 with demineralised water....
PostPosted: Mon Sep 06, 2010 7:59 pm
As far as i know water wetter is as MG Rocket said. I believe a lot of racing car teams use it for the better heat transfer. I know for a fact 1 of the v8 racing utes uses it and would assume most of them if not all do as well.
PostPosted: Mon Sep 06, 2010 9:22 pm
I'm employed by Toyota and there are now two different "red" coolants.
The original "red" coolant is called -Longlife coolant,that's the type that you mix.
Now they have a product called- Super Longlife and it's bright pink,this one is used without mixing with water.
Toyota also say that the two different Coolants are not compatible with each other. :o
I'll keep using the redline product :)
Users browsing this forum: Bing [Bot], drmini in aust and 106 guests
