It is currently Sat Jul 05, 2025 3:42 am
Post new topic Reply to topic  [ 223 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 15  Next
PostPosted: Thu Sep 09, 2010 8:04 pm
There are a few marks on the insert from porting but only away from the seat. I think the seats are done pretty quickly from the factory. Like I said they do seal but I want to make sure they keep sealing for a while yet. I wasn't convinced the would last long. Guides were removed /shortened and belnded in.
I'll go back to using my 1.5 Roller rockers now the Valve springs have been upgraded. Dellortos all rebuilt and linkage sorted. I'll have to use my perry lcd until some more $$$ comes for an exhaust. Rang Link Auto. re Brownriggs and he is waiting to sort out someone to bend the outer pipes for him as the guy who was doing it sold his gear. They might be ready now though? Anyone know?
Now with 2 extra ports!
PostPosted: Thu Sep 09, 2010 8:26 pm
I've been waiting three years for mine. I ring every six months and get the same story. Someone has said previously here that a brownrigg copy is available, but I dont know where from.
Member VMCI #19
PostPosted: Thu Sep 09, 2010 8:48 pm
I emailed Link a couple of years back, I needed a Brownrigg Y-piece. Never ever got a reply... so I sold em.
You might have to settle for a Maniflow or something.
PostPosted: Thu Sep 09, 2010 11:19 pm
He He, I bought em of the doc! Anyone know if they have y pieces now! 8)
Cheers Doc! :P
Sir Alec! we are not worthy!
PostPosted: Fri Sep 10, 2010 9:04 am
I tried to get a new Y piece form Link for ages with no success, in the end I gave up and got one made locally. Don't they want your business? Ron B was always so helpful.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Sep 13, 2010 9:03 am
From Martin
"We have just sold out of our production run of 100 heads. We will have more in at the warehouse in a week or so. There will be a small price increase on the heads. The foundry production cost went up a little $100usd per head, so we will increasing the price a bit to compensate.
Ps, I'm in the process of sourcing small 12mm velocity stacks to use on the weber 40s as these allow for better hood clearance. We had been trimming ours but this will look cleaner."
Ty
PostPosted: Mon Sep 13, 2010 9:12 am
Not much room in there with twin Webers..
Are all you guys with roundies going to run without filters, or mount a big ugly schnoz on the bonnet to give some room?
PostPosted: Mon Sep 13, 2010 2:25 pm
neither, opening up the bonnet to allow room for the filters to stick through. Let the world see whats in there.
1962 Mini Speed sports sedan
PostPosted: Mon Sep 13, 2010 2:39 pm
I always liked the rather raunchy look of four ram pipes sticking out the front of the bonnet. But I'm not sure how legal that would be.
Similarly you used to be able to remove the grille in summer but I'm sure that too is frowned on nowadays.
So my ideal "means business" look is: 4 ram pipes out the front of the fibreglass bonnet, no grille and 4 slide lock type bonnet pins.
It's only a Mini officer.....
Slide
PostPosted: Mon Sep 13, 2010 2:52 pm
Have you seen my previous black mini. I think 4 ram tubes out the front is taming it down a little. Cops arent that bad, as long as it meets the traffic guidelines for bonnet scoops etc shouldnt be a problem. G.
PostPosted: Mon Sep 13, 2010 3:11 pm
I'll try it out and see what if any clearence there is. Thinking of the carbon fibre buldge bonnet.
PostPosted: Mon Sep 13, 2010 8:38 pm
Many brands of weber replacement throttle bodies are really short and will allow clearance. The plan is to either use two of those or make a manifold with injector ports & plenum and use a single throttle body, similar to the dodgy one I brought to the Muster. (did anyone see that?)
Check out these, only 30mm long! Plenty of room for a ram stack and sock!!
http://www.compsystems.com.au/images/st ... TS_bbw.gif
http://www.kinsler.com/Cat_32_Pgs/Cat_32_4_09_Pg_48.pdf
http://extrudabody.com/Products/ITBs.html
http://www.injectionperfection.com.au/c ... iew/21/71/
http://www.efihardware.com/products/12/ ... mm-to-50mm
PostPosted: Mon Sep 13, 2010 10:11 pm
i wonder whats in here
surprised?
PostPosted: Mon Sep 13, 2010 10:30 pm
yeah look, i have to agree,,, these days it`s just sooo easy to inject,,, & fuel economy is also important these days,,, carbs just can`t beat the economy of a well set-up sequential injection system without sacrificing performance.
PostPosted: Mon Sep 13, 2010 10:57 pm
Thats getting very interesting now, looks like you could buy the head with the webers, sell those and inject it with the money from selling.
All very interesting indeed.
Simplify and add lightness
