It is currently Thu Jul 24, 2025 6:36 am
 Post subject: gemini starter
PostPosted: Tue Sep 14, 2010 5:30 pm
Hi this has probably been asked before but couldn't find it in the search but what gemini starter do i need the one i had here to put in was from a rb gemini (front wheel drive)and it's not the same size as the hole in the bellhousing so i am thinking i should return it and swap it for a earlier one from a rear wheel drive?? any help please
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Tue Sep 14, 2010 5:44 pm
As you have found the RB one is no good. You just need one from any RWD Gemini. (except the diesel ones.)
PostPosted: Tue Sep 14, 2010 5:52 pm
TE or TF I think were the model designations for the later RWD (more squarer looking cars). I'm guessing the earlier; smaller shape may well fit too, but mine came off a TE definitely.
PostPosted: Tue Sep 14, 2010 6:03 pm
Mods rock!
I believe one from a Rodeo Ute also fits.
PostPosted: Tue Sep 14, 2010 6:05 pm
thanks guys thats what you get for sending the wife shopping :lol: have to send her back again to get another
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Tue Sep 14, 2010 6:06 pm
And the early Jackaroo as well.
PostPosted: Tue Sep 14, 2010 6:56 pm
Resident Haemorrhoid
the early Morris starters fit as do the leyland starters :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Tue Sep 14, 2010 6:59 pm
Heritage MG sells new `Gemini pattern' pre-engaged ones, they are $163.
These bolt straight on, no mods needed- they have been made with the mounting holes slotted to fit.
http://www.mgspareparts.com.au/index.ph ... &Itemid=26
[edit] they look like this-
Last edited by drmini in aust on Tue Sep 14, 2010 10:24 pm, edited 1 time in total.
PostPosted: Tue Sep 14, 2010 7:07 pm
I have one of these, very good
Lillee - 1969 Morris Mini K
PostPosted: Wed Sep 15, 2010 8:46 am
same.. but the verto type one..
kick ass. i love the sound when it starts as well :D
PostPosted: Wed Sep 15, 2010 11:02 am
Dumb question but what's the benefit of one of these over the standard unit?
Reduced size, cranking capacity?
Cheers.
2008 Prado GXL
PostPosted: Wed Sep 15, 2010 11:06 am
Cheers.
1. More cranking torque.
2. Are pre-engaged, so they don't chew your ring gear up.
3. They mesh in from the front, so still work OK if your ring gear teeth have damage from the Lucas bendix throwing in at the same place (on the other side).
Disadvantage- will not fit with a Cooper S oil cooler in the usual place.
PostPosted: Wed Sep 15, 2010 12:20 pm
TG is the last RWD i think, i got 2 off my mate when he got rid of all his gemini parts
PostPosted: Wed Sep 15, 2010 12:52 pm
Anything from a G161Z/G1800Z or G200Z would be all the same I would assume.
 Post subject: Pre Engage starter
PostPosted: Wed Sep 15, 2010 12:57 pm
I only have one left Gemini Starter. If any one needs a pre engage type starter that will fit even with an Oil Cooler mounted in front you will need one of my special Planetary geared starters. These can start any size Motor with ease and they are much lighter than original Lucas or Gemini startes too.
"Let us remove your "SHORTS"
