It is currently Mon Aug 04, 2025 1:40 am
PostPosted: Tue Sep 21, 2010 11:50 am
...............without smashing it!
Can anyone give me any quick tips?
Ive gotta old sliding window door that i found in the shed, and I wanna keep the glass outa it!
8)
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Tue Sep 21, 2010 12:03 pm
Remove the catches
Then buried in the rust, crap and remains ot the flocking of the bottom channel are 3 tiny screws - approx each end and the middle - find and remove by what ever means will do it - bottom channel then comes out and the window with it
Good luck
David L
Dig along the the bottom of the sliding window channel and you will find two or three phillips head screws. Get them out however you can and this is sometimes difficult because the original screws are steel and they rust. You may have to drill the heads off. I use stainless ones at reassembly time.
Once the screws are out, slide a flat putty knife under the chrome channel inside the door and move it along from front to back. When it is free, the two windows, the chrome rail and the track will all come out of the door as one assembly. Make sure you have a a good hold of the glass as the whole thing will eventually come out in a rush and a glass can easily drop.
I think that's it.
Al
PostPosted: Tue Sep 21, 2010 1:11 pm
Cheers guys! will retire to the shed soon and sort it!
I havnt ever played with sliders before! I'm greatful for the help!
Regards
Cam :lol:
PostPosted: Tue Sep 21, 2010 10:20 pm
All the above - but prop the door upside down more or less vertically against a wall/bench etc. Then, when the bottom frame comes loose, you won't be trying to juggle two pieces of glass as they rush towards the floor!!
Cheers, Ian
