It is currently Thu Jul 31, 2025 8:18 pm
 Post subject: Blower Fan
PostPosted: Wed Sep 22, 2010 10:03 am
As i have taken the rattly bastard of a heater unit out of the car, as a part of rego it is a requirment that you have a blower to blow on the windscreen for defrosting in cold weather.
What i am looking for is a barrel type fan that is the same diameter as the flexible cardboard hoses (i use plastic vaccum hoses).
What i would like is to put the fan inline with the hoses so that it is hidden behind everything.
PostPosted: Wed Sep 22, 2010 10:06 am
Computer fan.
Might be low flow but might scrape through rego.
:lol:
PostPosted: Wed Sep 22, 2010 10:07 am
I seem to recall someone on this forum saying that they used a couple of computer fans, and it passed rego. I reckon you might be able to get some from jaycar or somewhere similar.
Or you could get some model aircraft jet engines and BLAST THE WINDSCREEN!
You could try something like this:
http://www.jaycar.com.au/productView.as ... BCATID=725
PostPosted: Wed Sep 22, 2010 10:13 am
Actually the model aircraft engines is a good idea........might impliment that one into my car.
:D
PostPosted: Wed Sep 22, 2010 11:13 am
After a bit of trimming this may suit?
http://cgi.ebay.com.au/Car-Auto-Portabl ... 5d2a9a59b7
Cut off the handle and relocate the switch.
 Post subject: Windscreen heater
PostPosted: Wed Sep 22, 2010 12:00 pm
Rover Cooper
Mick has a small engine that heats at the same time, you may want to check that one out.
im a systems administrator, im sure i have a box of them lying around here in my office. i was hoping to find something a bit more robust, like a proper tube fan. Ive been looking but havent found anything really suitable in 12V
hair dryer insides might be a great idea, put them inside a bit of pvc piping of the correct size.
PostPosted: Wed Sep 22, 2010 12:02 pm
Give Ash some flowers Nick .
Bilge blower come in a few different sizes and in 12V
http://shop.ebay.com.au/?_from=R40&_trksid=m570&_nkw=bilge+blower&_sacat=See-All-Categories
PostPosted: Wed Sep 22, 2010 12:05 pm
Milatsmadmini
or....
http://cgi.ebay.com.au/200W-12-VOLT-CER ... 058wt_1137
PostPosted: Wed Sep 22, 2010 12:31 pm
thanks for the links, im leaning towards this
http://www.whitworths.com.au/main_itemdetail.asp?item=40000&search123=dryer&intAbsolutePage=1
take nozzle off handle off, wire the 12 volts and then wire the switch to the dash switch. its got a heater element in it too, bonus.
PostPosted: Wed Sep 22, 2010 5:59 pm
I am a bit of a blower fan myself but not the kind your talking about :wink:
PostPosted: Wed Sep 22, 2010 10:09 pm
i guess your just full of hot air :shock: :D :D :D :D :D
