It is currently Sat Jul 19, 2025 10:36 am
PostPosted: Sat Aug 14, 2010 7:59 pm
car started blowing serious amounts of exhaust smoke today. Ok at idle but under acceleration lots of bluish smoke. Haven't checked much yet other than oil cap which looks ok in terms of no white stuff. Wil probably take it to mini classic this week anyway but just thought I'd ask what's likely. Is it just mixture or something more serious?
PostPosted: Sat Aug 14, 2010 9:38 pm
Usually, light blue smoke = oil burning.
Usually, under power = it's coming up past the rings.
Usually, only after starting up cold or at bottom of a hill = its coming down the valve guides.
However, this is only a general view, there are exceptions to the rule.
How many miles has the engine done, and how long since it's had a valve job?
PostPosted: Sat Aug 14, 2010 11:11 pm
Completely new (rebuilt) engine in 2005. No particular work done since internally that I can recall.
Been reading up, things like piston rings and valve seals and so on, huh? Probably out of my capabilities in terms of diagnosis. I'll give Greig a call on Monday and see when I can get up to Ermington. God I wish there was a mini mechanic closer to me :(
PostPosted: Sun Aug 15, 2010 7:12 am
Mods rock!
Easy to fix, should take all of about 10 minutes. Drain the oil out :lol:
PostPosted: Sun Aug 15, 2010 11:52 am
did you do an oil change. what oil did you put in. its not to thin or to thick is it. It is mineral based and not synthetic.
Might also be worth having a compression test on it to make sure the piston rings are good.
PostPosted: Thu Sep 23, 2010 10:16 am
talking about the light blue smoke;
What would be the reason to see smoke under fast cornering only?
PostPosted: Thu Sep 23, 2010 10:20 am
Tyre smoke?
PostPosted: Thu Sep 23, 2010 10:27 am
no not from the tyres, coming from exhaust (I think oil) but then stops. Only when I am cornering too fast.
PostPosted: Thu Sep 23, 2010 11:27 am
i noticed my engine blowing some blue smoke this morning. on startup and when taking off from a stand still.
the smoke disappears when the engine revs or is under load at rpm.
this would be valve stem seals yeh?
PostPosted: Thu Sep 23, 2010 11:28 am
i have the early oring type valve stem seals. should these seal ok? engine only done just over 1000 kms from new.
i should have upgraded the guides to suit the later hat type valve stem seals.
may have to pull the head and do that i think.
PostPosted: Thu Sep 23, 2010 11:41 am
Firstly check that it`s not OVER-Full with oil
too much oil & they don`t like it ,,, & they tell you that by smoking
but otherwise maybe a piston ring problem
you don`t have a brake booster (servo) fitted do you???
PostPosted: Thu Sep 23, 2010 11:56 am
My oil level is okey and I do have brake booster.
I first seen the smoke today when I was flying through corners up the multideck carpark in Crown
PostPosted: Thu Sep 23, 2010 7:53 pm
If only visible on long LH bends it could be oil flung up the flywheel housing breather by the primary gear.
Mine used to do that, when the Cooper S PCV valve used to stick open.
PostPosted: Thu Sep 23, 2010 11:01 pm
interesting that this thread was dug up.
my problem that kicked off this thread was that the Brake Master Cylinder was leaking into the brake booster and then the fluid was being sucked up in to the manifold and burning off!
PostPosted: Fri Sep 24, 2010 9:45 am
Thanks drmini,
that might be the case because on the way back yesterday I did not see any smoke at all. I think I will stop cornering that fast now.
Users browsing this forum: Google [Bot] and 109 guests
