It is currently Fri Jun 27, 2025 12:38 am
 Post subject: Whats this??
PostPosted: Thu Sep 30, 2010 12:45 pm
Hey guys.
I was changing my oil this morning and this small spring was on the sump plug. Its around 2cm in length. Any ideas about what it is and if its anything bad?
Cheers Matt
PostPosted: Thu Sep 30, 2010 12:52 pm
Hmmm... looks like part of the spring that keeps tension on the primary gear seal :?
Does the clutch judder at all?
Jacob
PostPosted: Thu Sep 30, 2010 12:53 pm
I think its the spring found inside one of the crank oil seals, they wind around inside the seals to improve sealing.
Do you have any oil leaks... yes i know all minis leak oil but can you pin point a leak from the radiator end or clutch end, if not you may have one soon.
Im sure someone else may know more than me tho
PostPosted: Thu Sep 30, 2010 1:18 pm
Nope don't have any oil leaks or clutch judder, but recently i noticed that the clutch isn't as hard as before, i don't need as much force to push it down, and it engages much sooner in the pedal.
Hope its nothing to major :? :(
PostPosted: Thu Sep 30, 2010 1:22 pm
I heard there have been probs lately overseas with these clutch seals losing their springs on assembly.
Wonder where they are made.... :roll:
PostPosted: Thu Sep 30, 2010 1:33 pm
Just went and had a look at the clutch split pin and not oil is dripping from there :?
Hmmm...china i guess :evil: :evil:
PostPosted: Thu Sep 30, 2010 4:36 pm
Delhi?............. :D
mooo, I'm a pig!
PostPosted: Thu Sep 30, 2010 4:51 pm
i reckon we need a thread devoted to "whats came out of your mini sump that wasnt oil" :lol:
PostPosted: Thu Sep 30, 2010 6:35 pm
Better out than in.
PostPosted: Thu Sep 30, 2010 9:38 pm
Tomboss Breweros
Shows those little magnets work.
Definately a spring from a seal but what one is anyones guess.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Oct 01, 2010 12:08 am
it could also be from the selector seal on a remote (two rods to gearchange box) although it looks too long. They always leak anyway. :D :D
if its from the primary gear seal, wonder if the rest is in the seal or been ground up by the gears.
only other place i can think of is the two seals on the diff side caps.
PostPosted: Fri Oct 01, 2010 12:57 am
If its the primary gear seal wouldn't oil be leaking from the split pin under the clutch housing?
PostPosted: Fri Oct 01, 2010 8:54 am
Not until the rubber itself goes hard.
should be allright for a while yet.
