It is currently Fri Jun 27, 2025 11:32 am
 Post subject: Build Date?
PostPosted: Fri Oct 01, 2010 8:19 am
Hi there,
A friend just bought an 850 ($500) and would like to know more about this little car.
YMA2S1 41855
The Wiper Motor says DRBA 5 63 12V
Can anyone narrow down the Build date from this info?
EDIT - More Pictures now in Spotted Section http://www.ausmini.com/forums/viewtopic.php?p=765415#765415. It's a "bitsa" as it has Clubman Seats, Clubman Tail lights, and now has a 998 fitted.
Dicko.
PostPosted: Fri Oct 01, 2010 8:48 am
i take it theres no compliance plate. the numbers men will be able to help you out.
heres a thread
http://www.ausmini.com/forums/viewtopic.php?t=50776
PostPosted: Fri Oct 01, 2010 9:35 am
Mods rock!
At a rough guess I'd say the later part of 63 or maybe early 64. The cover on your wiper motor is from May 63.
PostPosted: Fri Oct 01, 2010 12:23 pm
jeez theres a bit of work in that one. good luck on the rebuilt and keep us posted.
PostPosted: Fri Oct 01, 2010 12:46 pm
That is a bitsa isnt it... Clubby boot lid, tailights, seats, later wind up non clubby doors....
PostPosted: Fri Oct 01, 2010 1:25 pm
always wondered if one would fit on the back of a ute!
is that a 3 metre tray?
i'd say it's a bargain.
PostPosted: Fri Oct 01, 2010 3:38 pm
Giday d1ck0, Good to hear from you. Is the blue F100 from around here?
A good way to check the age of the body is to have good look at the glass. It very likely the rear side windows are original to the body. Have a close look at the stamp on the glass. There will be a little tiny dot (can be quite hard to see) above one of the letters. You know the decade the car was made, so count the number of the letters to the dot, eg if it's above the 3rd letter
is was made in 1963 and so forth. You can check all hardened glass on old cars this way. Newer cars have multiable dots so I don't know how that works.
Users browsing this forum: Bing [Bot] and 79 guests
