It is currently Tue Jul 22, 2025 5:29 pm
PostPosted: Sun Oct 03, 2010 10:02 pm
Yes it's 4 synchro, not sure of diff ratio in that 22G846 casing.
Mini K and 1098 Clubby were both 3.647, Mk2 S was 3.444, but the pov pack vans with the puddin' stirrer gearshift I'm not sure.
If motor is off it you can paint a mark and count the teeth.
3.647 ratio has 17T pinion and 62T crown wheel.
A 3.765 one has 17T pinion and 64T crown wheel.
PostPosted: Mon Oct 04, 2010 5:57 am
Pretty sure I read the 22G846 part was the original Elf/Hornet 4-sync casting. They look identical to the 1128 part, though.
All the povo pack donks/gearboxes I've come across have had the 3.647
Jacob
PostPosted: Mon Oct 04, 2010 6:45 am
Thanks guys, will pull diff out when i get back from Central Coast, meeting josh from Mini Imports to pick up a set of seats. :D
PostPosted: Mon Oct 04, 2010 2:21 pm
Pulled box apart, all looks good but i think i will put a rebuild kit through it anyway. diff ratio is 3.64. 8)
Users browsing this forum: ken@miniauto and 79 guests
