It is currently Mon Jul 21, 2025 10:40 am
 Post subject: Water Leak around screen
PostPosted: Mon Oct 04, 2010 1:06 pm
When I drive in rain at speed (90-100 K) i get water leaking out from under the outer edge of screen rubber and also (I think) from just under the corner of the top dash rail.
I suspect it is being blown up into the top corner of the inside of the guard and then under the lower corner of the windscreen surround/scuttle panel.
I think it then works its way past the windscreen rubber and also under the top dash rail.
I haven't taken the dash card out yet to have a good look but what should I do to rectify this?
I don't want to go bogging things up in a way that might then trap water and cause rust.
I normally don't drive in the rain if I can help it but I would like to fix it if possible.
PostPosted: Mon Oct 04, 2010 1:33 pm
Id just let it dry out and reseal the windscreen rubber on the body and screen
PostPosted: Mon Oct 04, 2010 4:27 pm
the lovely smell of selastic
PostPosted: Mon Oct 04, 2010 4:40 pm
Only if you are stupid enough to use Silastic. :roll:
PostPosted: Mon Oct 04, 2010 5:05 pm
Die Die Die!!
buy a late model front windscreen seal, the wider ones.. they are much better and they are 1 peice
PostPosted: Mon Oct 04, 2010 5:15 pm
works for soooo many things its great. gaskets, sticking carpet down, sealing leaks. love the stuff, just not the smell.
PostPosted: Mon Oct 04, 2010 5:20 pm
You will regret it eventually if you keep the car long enough.
PostPosted: Mon Oct 04, 2010 6:32 pm
Because it's going to cause rust yea?
PostPosted: Mon Oct 04, 2010 8:59 pm
More likely it doesnt unstick.
Simplify and add lightness
PostPosted: Mon Oct 04, 2010 9:55 pm
Yeah but I think its more than just around the screen. I can feel a draught of air under the top dash rail and right up in the corner. I think it was coming in there to.
Guess I'll have to take out the dash card and have a good look.
Could I try forcing some windscreen sealant (or whatever that black stuff is that never sets) under the rubber and into any openings I find?
PostPosted: Mon Oct 04, 2010 10:04 pm
Butyl mastic is the black windscreen sealer you want. If there are any holes I'd fix them with Sikaflex or Selleys All Clear, not Silastic. Common silastic is acid cured... :x
Users browsing this forum: BrisbaneMini and 103 guests
