It is currently Sat Jul 19, 2025 3:53 am
 Post subject: clutch seal removal
PostPosted: Sun Oct 03, 2010 10:57 am
OK I want to remove 2 clutch seals that are already installed, without taking the flywheel housings off.
I'm looking at making a puller from and old clutch plate, which will clamp to the primary gear splines with a plate across the end of the crank, just turn a bolt and pull it and the seal out.
I made one of these a zillion years ago but lost it.:oops:
Q- is there an easier way. :P
I usually change em with the motor out and flywheel housing off......
 Post subject: Re: clutch seal removal
PostPosted: Sun Oct 03, 2010 11:50 am
put a screwdriver beside it and twist... ;)
PostPosted: Sun Oct 03, 2010 12:01 pm
I have a slightly modified small 3 leg puller (slight grind to reduce the thickness of the toes on the legs) that grips behind the clutch splines. Doesn't take much to pull out the seal. Bit of a fiddle getting the 3 legs positioned but when you get some tension on its OK. Works for me.
PostPosted: Sun Oct 03, 2010 12:55 pm
Easier way....
the BMC tool for it..... :lol:
Perhaps can make up something along these lines.....
(even works to remove primary gear when the bearing has spun :cry: )
PostPosted: Sun Oct 03, 2010 5:57 pm
Mods rock!
Errr......not a good idea at all.........
MINImal effort wrote:
Easier way....
Yeap, made one years ago. Works a treat.
PostPosted: Sun Oct 03, 2010 9:46 pm
I can knock one of those tools up, no problem. thanks for the pics... :wink:
PostPosted: Mon Oct 04, 2010 1:43 pm
Mods rock!
I've also got another tool I made for putting them back in with engine in car.
PostPosted: Mon Oct 04, 2010 7:15 pm
Kev
This should make things easier
Kiwiinwgtn
PostPosted: Mon Oct 04, 2010 7:41 pm
Thanks heaps kiwi, saves me the hassle of drawing one up. 8)
PostPosted: Tue Oct 05, 2010 11:35 am
Progress:
This morning I used my 2 leg puller coz I have one, with a thick cable tie cinched round the legs.
Seal came out easy, but.....
As the primary gear butted up to the back of the seal, PING!!! that bloody seal spring parted & went `boing' in amongst the drop gears.
So, the &&%^*!^% flywheel housing has to come off, anyway. :twisted:
I may as well have pulled the cover first and saved myself the trouble. :lol:
PostPosted: Tue Oct 05, 2010 12:47 pm
Mods rock!
Progress:
....................don't you just luv it?
PostPosted: Tue Oct 05, 2010 1:00 pm
Ah well plenty of time, the new seals haven't landed yet.
BTW the old seal was pretty worn, considering it's only done 11,000 miles and there's no grooves in the primary gear.
Whoever is making these cheapo seals shouldn't bother. :lol:
PostPosted: Tue Oct 05, 2010 1:15 pm
Kiwiinwgtn
Any details on that book? - Author - year? Library catalogue number?
David L
PostPosted: Tue Oct 05, 2010 3:57 pm
Sounds like bad luck with the spring - and may explain a similar spring someone found in an oil change recently...... :?
That book does look interesting..... especially if more info like that....
From the page heading I suspect it is
"BMC minis" by David Marshall & Ian Fraser
(or full title "BMC minis: maintenance, tuning and modification" )
I've ordered a copy via http://www.abebooks.com
PostPosted: Tue Oct 05, 2010 4:09 pm
Funnily enough it is also in the book "BMC 1100s: Maintenance, Tuning and Modification" by David Marshall & Ian Fraser. :lol:
Users browsing this forum: Bing [Bot] and 87 guests
