It is currently Sat Jul 19, 2025 11:04 am
 Post subject: Rear wheel bearings
PostPosted: Tue Oct 05, 2010 9:56 am
Just fitted a set of tapered rear wheel bearings and was wondering, how tight do you do up the hub nut? I've been told that they should be done up tight then backed off about one castelation on the nut. Does this sound about right? Any help would be great. Thanks, Frank. :D
PostPosted: Tue Oct 05, 2010 10:08 am
This space for rent
The book says 60 ft-lb and then align to the next split-pin hole (i.e. don't back off). But since the rear stub axles are fixed and don't transmit any torque, some people just do them up tight-ish and fit the pin.
Personally, after going through several sets of tapered bearings by not setting the preload correctly, I now make sure the preload is correct and torque up as per the book.
No do them up tight to the next castelation. You really need a torque wrench as how tight is tight? It's not something you want to get wrong...
60ft/lbs is what you need to do them up to, that is pretty tight.
PostPosted: Tue Oct 05, 2010 11:59 am
There`s 2 ways to set tapered rear wheel brgs
with the center spacer
or without
With the spacer you tighten the nut up tight & to the next castelation for the split pin,, BUT!!!! that is only """"IF""" the spacer is the correct thickness---> too thin & you will over load the pre-load & pre-mature wear is imminent,,, too wide & wear is also pre-mature because they are running loose,,, so the thickness of the spacer is crucial
if running without the spacer then nip the bearing up till the brg is "Firm-ish) & then back it off a tad till it turns free but with no play,,, slip the split pin in & you`re away,,,, as per Holden front wheel brgs
PostPosted: Tue Oct 05, 2010 12:44 pm
Mods rock!
With the latest tapered rollers that have half a spacer on each bearing, the pre-load is too high. I put a single 0.005" shim between them and it's right then.
PostPosted: Tue Oct 05, 2010 12:57 pm
So basically avoid Minis then...? :lol:
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Tue Oct 05, 2010 4:10 pm
.... and I presume you are already aware the LEFT side nut has an opposite thread direction to normal just to confuse matters.....
(eg instead of lefty loosey and righty tighty * - left is tighten and right loosen)
(though when I came to service my race mini found that it had been modified and fitted with a right hand axle stub so was "normal" :roll: took a while to realise :x )
* (learnt that at Circ de Solei :lol: )
