It is currently Mon Aug 04, 2025 11:22 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Oct 05, 2010 8:01 pm
Mods rock!
jester99 wrote:
they were part of the cost saving excercise when i built this engine. the cost was supposed to be within reason, but this has blown out of house and home :lol:
love to get a set of full rollers but need money for that.
these will have to suffice for now.
Those rockers are OK, they are just not the best of standard parts, but quite OK. Just don't pull big revs and don't expect a high life from them.
PostPosted: Tue Oct 05, 2010 8:03 pm
Welded steel pressed, welded steel pressed! :lol:
Lillee - 1969 Morris Mini K
PostPosted: Tue Oct 05, 2010 8:05 pm
:lol: so much for driving to work tomorrow :lol:
PostPosted: Tue Oct 05, 2010 8:08 pm
hey mate, like doc says, those springs look coil bound to me as well. Same problem we found I had with mine, which caused a lot more damage and bit into my pocket. It broke 2 valves at which dropped into the cylinder.. and well the rest is self explanatory what happened after that. I would change yours ASAP if I were you..
What sort of cam do you have in the thing?
PostPosted: Tue Oct 05, 2010 8:11 pm
its not a big cam, a 731. which is .263 lift inlet, .320 lift exhaust, 268 duration 24/64 29/59 range 2500-7000rpm.
PostPosted: Tue Oct 05, 2010 8:13 pm
thaks for your help guys, im off to whip the head off and change them out.
might as well change the guides while i am at it. hey its only money yeh! :lol:
PostPosted: Tue Oct 05, 2010 8:16 pm
:lol: :lol: well at least you dont have a big lumpy thing like me, ive got 320 degree race cam, :oops: had wayyy to much lift for my springs and well pop goes the weasle and pushed my valve through the collet. Great times 8) :lol: NOT
yeah if i were you, i would be changing them as sap :)
PostPosted: Tue Oct 05, 2010 8:32 pm
GT mowog wrote:
If that is ALL that is the problem, the spring can be changed without removing the head. There is an adaptor that screws in the spark plug hole for connection to your air compressor. Make sure that cylinder is at BDC before turning the air on.
Ive actualy done this and it works great , took me about 5 mins to remove and refit a new spring, sooo easy, if your not in a hurry id post the jiggers up to you if you like
PostPosted: Tue Oct 05, 2010 8:36 pm
thanks mini maxx, but i am in a hurry.
will find someone locally tomorrow who can help.
cheers.
PostPosted: Tue Oct 05, 2010 8:44 pm
cheers.
No Worries Jester, Good luck with it :D
PostPosted: Tue Oct 05, 2010 9:45 pm
& flick those stupid spring clips off the colletts too while you`re at it,,, they do nothing except "Maybe" ping off & fall into your engine "somewhere"
PostPosted: Tue Oct 05, 2010 10:37 pm
everyone has bagged those rockers.
id like to ask why, why will they drop performance, is they give slightly more lift. Ive heard they can snap, but never experienced it. All the steel pressed ones ive seen have worn tips. These ones dont seem to wear as much at the tip.
i could understand the risk of snapping on a high end motor, but for general fast road use whats wrong with them.
PostPosted: Tue Oct 05, 2010 10:50 pm
nothing,,, they`re rockers,,, you need rockers for the engine to work,,, so there is a set of rockers that will help your engine work, that`s about it
they do wear on the tips & quite bad in fact
they also have no bushes inside (for the shaft)
they do break-snap (i have seen it)
Full Roller rockers can be a big money pit too
roller bearings are not actually very good at rolling a mick-hair one way & then back again,,, all that does is allow each roller to dig into the surface of the shaft
most roller "Tip" rockers are just a pin with a roller on it,,, the little tiny weeny pin just digs into the roller ,,, not much rolling of the roller goes on at all
I`d rather a set that "swipes" nicely & correctly
I`d rather that people actually set-up their rockers instead of just bolting "a set" on without making sure they`re angled correctly & their springs don`t bind & the swipe is correct & & 7 &
any HP loss is usually from the fitment ----->>>> (the person fitting them)
sorry for the rant, i have the flu
PostPosted: Tue Oct 05, 2010 11:12 pm
flu, lemon, honey, tea, warm, add half a glass of whiskey. flu gone in the morning.
PostPosted: Wed Oct 06, 2010 11:18 am
so i just need a set of 526 springs and flick the clips yeh?
will the current collets still be ok etc?
Users browsing this forum: fuzzy-hair-man and 106 guests
