It is currently Mon Aug 04, 2025 1:21 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Oct 06, 2010 11:41 am
Hey
Yeah the clips go into the scrap metal bin...
The colletts you need is based on the valves you're using, so as you're not changing them you'll be right.
Yeah the 526 springs have served me well in the past...
Jacob
PostPosted: Wed Oct 06, 2010 10:28 pm
ok i bought a set of 526 springs, a set of late guides and a set of late valve stem seals, the hat type.
i have the head off, and am taking it to a head specialist tomorrow to have it done properly.
couple of questions if someone may be able to help.
on my old 202 head which has the later type valves, the top valve spring retaining washer is different, the collets sit deeper into it.
on my 295 head it has the early type valves with the single wide groove and the clips etc.
my question is, can i or do i need to use the top valve spring retainer washer off the 202 head as it allows the colect to sit deeper into it?
or do i use the origonal ones on the 295 head now?
here is some pics to show what i am talking about, this is the 202 head
and the below pic is the current 295 head with the early setup.
so, i discard the clips, use the 526 springs, and do i use the early or later top retaining washer with my early valves?
PostPosted: Thu Oct 07, 2010 5:53 am
The colletts suit the valves.
You'll need to keep using the early type unless you want to change all the valves in the head as well! You can't use the later colletts on early valves.
No need to change to the later type if the valves are in good condition.
Jacob
PostPosted: Thu Oct 07, 2010 7:41 am
ok cool. the valves are brand new, its all brand new, only done 1800kms :lol: just had the wrong springs 8)
thanks again
PostPosted: Thu Oct 07, 2010 8:41 am
Mods rock!
Can I also suggest you check your valve lengths.
With basically standard components and the cam lift that you have, I find it at odds as to how your could be getting anywhere near spring crush.
When the head is assembled back on the engine, you should check for spring crush by ensuring that you can get a 0.050" feeler strip between the spring coils when the valve is fully open. Be sure to check every one.
PostPosted: Thu Oct 07, 2010 10:45 am
The wire those old springs were made from is very poorly drawn, any drawing marks like those have are a recipe for eventual failure.
I do hope your new springs look better in this respect. :wink:
PostPosted: Thu Oct 07, 2010 1:52 pm
looking at the above pics, it looks as though the spring heights are quite different between the early & late type top retaining washers.
hey, the failure may be caused by poor/low quality springs and not spring crush. but they do look very compressed at full lift. but i have not measured them.
i will measure it all once i put the head back on with the suggested correct springs.
head went to specialist today so all going well should have it back tomorrow.
PostPosted: Fri Oct 08, 2010 1:18 pm
just had an interesting call from the head specialist.
he says with the valves i have, the retainers and collets, and with those 526 springs, i will need to machine the valve guides down aorund 3mm to stop the retainer from binding on the top of the stem seal/guide!
i have given him the go ahead to machine them to what he suggests is right, but does this sound right?
he says those springs will stop the spring bind but the guides need to be machined down.
PostPosted: Fri Oct 08, 2010 6:12 pm
Was going to mention to check the clearance between the retainer and the top of the guide (with seal on inlets) at full lift. 3mm seems a lot. I wouldn't do it. Do your guides have the recess for the top hat seal? If so and you intend to run these, no point in taking the top off the guide as the seal will still sit up, if you get what I mean.
On my race heads, to accommodate .500"+ lift at the valve, I push the guides down, inlets more than exhaust because of the top hat seal, to get clearance. I've never had a problem doing it this way.
I have made a tool to install valve guides and have spacers at different heights for this very purpose. If you get stuck, go talk with Ken at Mini Auto.
Steve
PostPosted: Fri Oct 08, 2010 7:43 pm
Mods rock!
jester99 wrote:
its not a big cam, a 731. which is .263 lift inlet, .320 lift exhaust, 268 duration 24/64 29/59 range 2500-7000rpm.
Something just doesn't add up here. Your Exhaust Valve lift is comparable to stock valve lifts. I have fitted many camshaft with up to 0.410" Lift with little - if any - head / guide modification. The top of the valve guide when fitted correctly should be 19/32" (15.08 mm) above the Valve Spring Seat.
What is the Casting No. of your head and what valves are you running?
PostPosted: Fri Oct 08, 2010 8:00 pm
does seems strange mate, i can't see this being right... something doesent seem to add up.. EDIT agree with Gt Mowog, i wrote this b4 i saw his reply, lol
PostPosted: Fri Oct 08, 2010 8:27 pm
I have it on good authority that those springs that broke are now made in China from inferior quality wire.
Others have had the same problem.
Minispares supplied C-AEA526 and 527 are OK.
PostPosted: Fri Oct 08, 2010 9:42 pm
Is there any difference in small bore valve guides and big bore, could the wrong guides be used to cause such a problem??
If 3mm needs to machined off the guide would this not of caused bent pushrods or brocken rockers or some such, NOT a brocken spring??
PostPosted: Fri Oct 08, 2010 9:49 pm
If 3mm needs to machined off the guide would this not of caused bent pushrods or broken rockers or some such, NOT a broken spring??
Smallbore guides are about 4 or 5mm shorter than 1275 ones. I'm not sure if still made- the last few smallbore heads I did, I had to shorten 1275 guides. The valves are a couple of mm shorter than 1275s, too. (apart from Mk1 S)
PostPosted: Fri Oct 08, 2010 9:52 pm
Smallbore guides are about 4 or 5mm shorter than 1275 ones. I'm not sure if still made- the last few smallbore heads I did, I had to shorten 1275 guides. The valves are a couple of mm shorter than 1275s, too. (apart from Mk1 S)[/quote]
So is the diameter the same?
Users browsing this forum: No registered users and 121 guests
