It is currently Fri Jun 20, 2025 11:13 pm
PostPosted: Wed Jun 16, 2010 6:51 pm
Looking at different ways to modify the heart of my mini, different engines etc, but thinking rather than going thru all the engineering hell of a different make engine, maybe just a supercharged baby instead, has anybody got 1 of these? What are they like?, performance wise, fuel consumption etc
cheers & thanks
Rohan
PostPosted: Thu Jun 17, 2010 12:51 am
I'm assuming you've checked this out already
http://www.hi-flow.com/HP3MiniSuper.htm
Thats the kit sold through link. a lot of other people on here are using bens sc12 kit.
1962 850,Frog
PostPosted: Thu Jun 17, 2010 10:15 am
what's the sc12 kit?
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Thu Jun 17, 2010 10:32 am
the SC12 kit is a manifold and other parts developed by Ben (and others?) who is a member on the forum. It uses the SC12 supercharger which was used on older Toyotas like the AE86 and various others.
It fits into the mini with little modification. Bens kit comes with all the parts you need to install it. You need the actual supercharger and a carby tho.
pm him for more details or do a search for it. heaps of info on the forum
http://www.ausmini.com/forums/profile.php?mode=viewprofile&u=919
1962 850,Frog
PostPosted: Mon Jun 21, 2010 10:01 pm
Im also setting one up!
ill let you know when i get it done you are more then welcome to check it out.
should be all going in maybe 2 months.
should have about 80 to 90Atw's and totally workable for a everyday car :)
just drop the compression of the head & maybe strengthen few things if you want to.
run a cross pin diff.
and you need a mild cam. like a 266 or 276. could go a re13T they make good power like O=MY GOD! power. at a gear box price ;)
http://www.miniaddicts.co.uk/forum/show ... php?t=2197
that will show you everything you need to know :)
PostPosted: Fri Sep 10, 2010 8:27 pm
Rang Link Automotive today :-) got costings on a complete engine incl S/C..
abit more than i was thinking (not by much tho) either way when the time comes, it is the road i will be going down :-) being that the car will be a weekend warrior this thing should last a lifetime for me and my kids....
i only want to build this mini once, not again in 5years time etc...
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Sep 10, 2010 8:47 pm
$8K ?
PostPosted: Fri Sep 10, 2010 9:06 pm
simon k wrote:
$8K ?
minus S/C :shock: :P
should mention that includes them buying an A+ engine/box as i dont have a donor engine for them....
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Sep 10, 2010 9:59 pm
there are a couple on ebay cheap
PostPosted: Fri Sep 10, 2010 11:20 pm
um wow thats a lot of money for a supercharged motor, that i assume would not a 'off its nutter' s/c motor??
OR is that fully worked - ie head flowed, lightened conrods, cross-pin/AT diff etc
Does that include a gearbox as well?
PostPosted: Fri Sep 17, 2010 12:58 pm
That Link kit used to be around the $5500 mark from memory.
PostPosted: Fri Sep 17, 2010 5:58 pm
You can now get a crossflow head and twin webers for a lot less.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Oct 10, 2010 12:52 pm
Bens SC12 Kit is great fun and if you have a motor already together its an easy bolt on performance. However a strong new engine and gearbox is a good idea. Also Link can tune them up for you if you have trouble with the carby.
Enjoy Chris ;)
PostPosted: Sun Oct 10, 2010 5:39 pm
The Vmaxscart kit with Eaton M45 Charger cost me around 2.8k delivered to Sydney.
Now for the engine build.
Not sure on this yet?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Oct 10, 2010 9:24 pm
Im bolting my vmax kit onto a metro turbo engine and box, its getting oh so very close to finished 8)
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
