It is currently Wed Aug 06, 2025 12:58 am
PostPosted: Sun Oct 10, 2010 8:17 pm
hi my car is drinking fuel like a v8 i am suprised it isn't running out the exhaust it is a 1100 with 276 cam and cooper s valves and a single 13/4" su it seems to be running ok where should i start?
PostPosted: Sun Oct 10, 2010 8:42 pm
What air filter are you running? try a drier needle?
PostPosted: Sun Oct 10, 2010 9:34 pm
Tomboss Breweros
Have you just built it?
Is it a new problem?
Anything changed recently?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Oct 12, 2010 10:43 pm
yes it has just been fully rebuilt but i haven't done anything with the carby yet as i was going to put a sc12 on it after it was run in and all the bugs worked out.
the air filter is just one of those foam ramflow ones.
i have just checked for any leaks and can't find not even a hint af a leak.
PostPosted: Wed Oct 13, 2010 8:18 am
Basic things to check first:
-Idle mixture correct
-Choke closes properly (check that the jet isn't stuck open)
-Check the float bowl level
-Timing
Get someone to put their hand near the exhaust pipe, and hit the gas. If they're hand is wet or black, you're running too rich - check the idle mixture, choke and bowl. If the exhaust is normal, it may be a timing issue.
PostPosted: Wed Oct 13, 2010 11:20 am
Is your fuel gauge correct?
