It is currently Sun Aug 03, 2025 5:06 pm
 Post subject: which way to Full
PostPosted: Sun Oct 10, 2010 1:05 pm
had to take the tank out to change the gasket as it was leaking but now I can't remember which way is up :roll:
PostPosted: Sun Oct 10, 2010 1:33 pm
Mods rock!
From your pic ^ if the float arm moves down & to the right, that should be full.
PostPosted: Mon Oct 11, 2010 4:33 am
Do the screw holes line up in any position?, i have found some senders will only fit up in the one position.
PostPosted: Mon Oct 11, 2010 6:37 am
Mods rock!
Quite true, all sender will only line up one way, so the float doesn't contact one of the internal baffles.
PostPosted: Mon Oct 11, 2010 11:59 am
Which way to full? Most fuel tanks fill from the bottom up
PostPosted: Mon Oct 11, 2010 1:21 pm
Mods rock!
Not Vans, well, not Gafmo's anyway.
PostPosted: Mon Oct 11, 2010 6:52 pm
Thanks for that ill put it back in tomorrow now :wink:
Users browsing this forum: Bing [Bot] and 73 guests
