It is currently Tue Aug 05, 2025 2:21 am
PostPosted: Sun Oct 10, 2010 2:06 pm
was browsing and dreaming about efi and i remembered that in the changeover from carbs to efi in mass production, there was a time when lots of small cars had single point injection...
has anyone replaced their carbies with this set up?
i'm just dreaming now, i think when i go efi it'll be in conjuction with an sc12 or a xflow head.... but that's probably a good lotto ticket away.
PostPosted: Sun Oct 10, 2010 4:07 pm
I'm pretty sure most mini's with fuel injection have the SPI instead of the MPI as MPI only came out for a few years. I'd assume SPI is slightly better for fuel consumption than a carby and MPI will only be a little better than SPI :roll: I think the main benefit is the "green effect" slightly less emissions for no real power gain. (Correct me if I'm wrong.)
PostPosted: Sun Oct 10, 2010 6:13 pm
Main benefit of SPI was better emissions and fuel economy, for a HP LOSS.
Hence why folks in the UK bin the injection and retrofit a carby or 2.
PostPosted: Sun Oct 10, 2010 6:18 pm
SPIs aren't that crash hot for fuel consumption anyway, they still average about 8-9 L/100km.
PostPosted: Sun Oct 10, 2010 6:28 pm
The only time SPI should be considered is in an intercooled turbo configuration :P
PostPosted: Mon Oct 11, 2010 8:13 am
ausmini mod
ausmini mod
The only time SPI should be considered is in an 8-port intercooled turbo configuration :P
Wouldn't do it on an N/A nor on a siamese port personally.
Pete
PostPosted: Mon Oct 11, 2010 6:26 pm
Pete
Maybe I'm dumb or old (yes to the latter) but why would you bother to use SPI on an 8 (or 7) port head when you have 4 nice separate inlet ports?? :?
Surely MPI is the way to go then.
PostPosted: Mon Oct 11, 2010 7:03 pm
I don't know about that, I get 41 mpg driving around Sydney out of mine.
And no I am not driving Miss Daisy. :wink:
Cheers Pete
PostPosted: Mon Oct 11, 2010 10:45 pm
Pete
I always figured with mpi (or individual throttle bodies to be precise) are for n/a only as its wasted effort to direct air more smoothly when its being forced through at 10-15psi.
Its easier just to chuck a single big throttle body and let everything be pressurised.
Nowadays the usual way is to have a single throttle body leading into one injector per cylinder.
Simplify and add lightness
PostPosted: Tue Oct 12, 2010 7:52 am
ausmini mod
ausmini mod
Pete
True - my point was I wouldnt INJECT a siamese port period... N/A or Turbo... but 7/8 port... absolutely. SPI, MPI, whatever setup but point being about 5 porters... thats all.
If I had the $$ I would get an 8 port and inject it, would look into all injection options and then work out what works best (and fits lol)
Pete
Users browsing this forum: No registered users and 115 guests
