It is currently Sat Jun 21, 2025 4:04 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Mon Oct 11, 2010 7:29 am
Im bolting my vmax kit onto a metro turbo engine and box, its getting oh so very close to finished
Im very interested to see what results you achieve.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Oct 11, 2010 9:49 pm
Questions re the Vmax kit. It runs an Eaton M45 from a MINI. Can anyone tell me the ratio in diameters of the crank and SC nose pulleys? With these, what boost does it give on a 1275?
What is a reasonable boost & compression ratio combination to run with a 1275 A series?
M
PostPosted: Tue Oct 12, 2010 9:30 am
I was advised that the Eaton M45 boost is around 7 to 9 lbs, but I have heard of higher boost figures happening. I will be fitting a boost guage to my engine when it is built but wont know real figures for a few months.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Oct 12, 2010 5:42 pm
Basically the engine is all but finished, just waiting on some parts for the box then will be good to go. Will run it in NA then taking it to a proper performance place for fitment of vmax kit, swapping to a gilmer drive belt system and hopefully suicide door conversion...but i digress.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue Oct 12, 2010 8:20 pm
An M45 is really quite big for a 1300cc. They are mostly on 1600cc or 1800cc cars. You can run the charger to 15,500 rpm so with an engine capable of 6,500 rpm and allowing for a loss here & there, the charger is 'theoretically' capable of giving a 1300cc engine 27 lb of boost! Now M45s don't like that much and a lot would leak back yadda yadda (don't go there) but it does show that it really is too mcuh charger for that size engine.
The real problem is using a charger this big and aiming for only 7 lb of boost. With the super-low drive ratio required, the charger is running so slowly, it isn't very efficient in the idle-3,000 rpm engine range, risking some of that positive displacement instant-boost goodness.
Hence my question. What is a reasonable drive ratio for the 1300cc engine and M45 combo? What is the reasonable limit of boost & static compression ratio? According to the calcs sheet on: http://www.sprintex.com.au/ 9 lbs of boost on a 1300cc will give 135 hp at 6500rpm.
The calcs are all really wooly since teh allowances for losses are wild guesses and the charger is being run off the chart (at the low end). I'm keen to know people's real experiences with them.
I'm asking because I have a spare M45 lying around in the garage :wink:
M
PostPosted: Wed Oct 13, 2010 9:24 am
I also have an M45, but it also has a Vmaxscart inlet manifold and a few other goodies..
Check out the Vmaxscart web site for more info.
Although I have not seen any published boost figures I do believe Graham Russell has seen some large boost figures on a kit he was working with a few weeks ago.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Oct 26, 2010 9:14 pm
all too expensive!
:D
http://www.ausmini.com/forums/viewtopic.php?t=66558
PostPosted: Tue Oct 26, 2010 9:44 pm
all too expensive!
Probably! But don't tell any one. :wink:
1969 Cooper "S"
1967 Mini Deluxe
