It is currently Sat Jul 19, 2025 2:02 am
PostPosted: Tue Oct 12, 2010 9:12 pm
Irish Yobbo wrote:
How about a speedo that's accurate?
The most accurate speedo I have is my tacho
PostPosted: Wed Oct 13, 2010 7:53 am
You should get a monster tacho with those lights that light up when the engine hits a rev point... then you need a fake turbo timer, a boost guage and some of those neon light dials which tell you when your subs are pumping too loud.
PostPosted: Wed Oct 13, 2010 9:51 am
This space for rent
1. Speedo (but only for the odometer)
2. Tacho.
3. Water temp.
4. Oil pressure.
5. Clock.
Anything else is overkill 8)
PostPosted: Wed Oct 13, 2010 10:26 am
I have but yet to install - Volt, Water temp, Oil pressure and tacho. Didn't want a big hooney tacho so got a small 2" one like the rest of the gauges and they will all line up in nicely together under the dash rail
David L
PostPosted: Thu Oct 14, 2010 7:03 am
thanks for all the replies. i think i can work something out from that.
PostPosted: Thu Oct 14, 2010 7:18 pm
some also like a GPS....but so many people tell me to get lost....I just don't
PostPosted: Sat Oct 16, 2010 1:24 pm
sgc wrote:
5. Clock.
Why do you need a clock. Overkill! :P
I've got Jag XJ6 SIII gauges to go in - oil pressure, water temp, volts, and fuel gauge. And a Triumph Speedo and Tacho, which I've got to get around to getting calibrated... :oops: Planning an Inno-style dash.
PostPosted: Sat Oct 16, 2010 1:26 pm
This space for rent
Tadhg wrote:
sgc wrote:
5. Clock.
To fill the hole left in the dash when I took out the old 2" tacho in favour of the column-mounted 4" MGB jobbie 8)
Plus, it reminds me how late I am... :roll:
