It is currently Mon Jul 21, 2025 11:43 pm
 Post subject: oil pressure
PostPosted: Fri Oct 15, 2010 7:48 pm
Hey i had a quick look but couldnt see anything.
Ive just installed a oil pressure gauge and im wondering what a decent oil pressure would be in my 1100cc?
Thanks Blake
PostPosted: Fri Oct 15, 2010 7:57 pm
Mods rock!
Cold it could reach 100 psi, but anything over 60 would be quite good.
Hot over 25 psi but closer to 40 would be happier.
PostPosted: Fri Oct 15, 2010 8:05 pm
ok cool thanks do it reading about 70 when i first turned the car on is ok?
Also whats the lowest the oil pressure can get before it starts to be dangerous?
PostPosted: Fri Oct 15, 2010 8:08 pm
A fresh motor should have 60psi hot @ 2500rpm and up, unless it's a Cooper or S- they run about 70psi when new.
Once an engine gets down to 40psi max when hot it needs new bearings and/or a new pump, in my experience.
Hot idle, down to 15psi is OK, it's not too bad yet.
PostPosted: Fri Oct 15, 2010 8:11 pm
Mods rock!
70 sounds good. The relief valve should be set somewhere around there anyway.
Hot at idle, I would want to see no less than 15 but would be happier with 20. On drive, hot, no less than 30.
PostPosted: Fri Oct 15, 2010 8:13 pm
Ok cool thanks. Its a fresh engine thats done about 1200k's.
70 is perfect
when she starts to get low pressure (below 25ish) top the oil up or change the oil & filter. if it doesn't rise its more investigation
