It is currently Mon Jun 30, 2025 4:01 am
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Jul 29, 2010 5:42 pm
Looking really good their Joe - and I like the colour.
Yes, its easier mounting the subframe up and then dropping the motor in from the top!!
Tricky
PostPosted: Thu Jul 29, 2010 7:51 pm
blue_deluxe wrote:
I drove the car it came out of. Went quite well for an auto in a heavy car. Got a few more engines lined up so one of those will be forged internals and a bigger turbo on it.
more engines?? upgrading later?
PostPosted: Thu Jul 29, 2010 9:03 pm
Good stuff Joe
Tricky does a smick job on those frames
like the color too nice and bright
Cheers Hallsey
PostPosted: Fri Sep 24, 2010 7:58 pm
Did a little bit more on it this arvo, doesnt look like much but ive got what cooling, fueling and oil lines i need. Just a case of ordering then onto the worst job, the wiring.
Simplify and add lightness
It looks like a whole engine there now lol.
PostPosted: Fri Oct 15, 2010 8:15 pm
Made a bit of progress today.
Got the cage mounted, need to drill the holes and shes in.
Whayt do people think of the placement of the cage? I think it could go back further but without the bucket seats to make sure i cant decide.
Or does anyone have a sparco rev seat they can lend me lol?
PostPosted: Sun Oct 17, 2010 10:22 pm
Nice work on the cage.. i'm doing mine at the moment too. One question though - is this car not going to be road registerable? It's just that from what i've read the cage has to be a min. 150mm from the back of the drivers head to be legal, i.e. half cage. Unless I read it wrong...
Answer the Question....
BUT always Question the Answer
PostPosted: Mon Oct 18, 2010 8:43 am
I hadnt heard of that one. My engineer just said as long as it meets the minimum thicknesses for tubing and is mounted properly. Ive got it sorted either way though, rejigged the cage around and now the main hoop is closer to the middle of the side windows.
PostPosted: Tue Oct 19, 2010 2:52 am
Joe,
You may want to check DOTARS VSB No. 14 I am sure a full cage is illegal.
Half cage is fine though.
Tricky
PostPosted: Tue Oct 19, 2010 11:16 pm
Archangel007 wrote:
Joe,
Tricky
Very interesting, id only read the Queensland modifcations guide and spoken the the engineer briefly.
The dotars stuff is here http://www.infrastructure.gov.au/roads/ ... eb2006.pdf
But i think ive found a loophole, it can be a 4 point with 2 points added for off road events, so the permanent points are the front roll hoop and the main roll hoop.
And it says that the centre roll hoop must be placed rearwards of the occupants heads to a maximum of 150mm. Seems a bit strange but better to keep the roof above the occupants whole.
It is going to be a 2 seater as well.
PostPosted: Fri Oct 22, 2010 3:19 pm
Ummm, no!
Refer to Figure LK15 in the NCPO VSB-14 Section LK - it strictly talks about main hoop and rear bracing, as shown in figure LK15. It does not say, not does it allow, the front bracing to be fitted to a standard road car as a permanent fixture.
Sorry to be a wet blanket, but I would hate to see your car get canned because of a misinterpretation.
Tricky
PostPosted: Thu Jul 21, 2011 8:26 pm
So how did it turn out?
Did u finish it?
Zulu...
1967 mini Cooper S
PostPosted: Thu Jul 21, 2011 9:58 pm
Its not really moved since the last update. I realised it was a massive project with a lot of skills required i don't have. Currently turboing and reshelling my soon to be daily with just a series power. Just to get the love of minis back.
PostPosted: Fri Jul 22, 2011 6:57 am
Good luck, Hopefuly it pans out for you! I know the feeling...
Life's a garden.... Dig It!
PostPosted: Fri Jul 22, 2011 12:07 pm
But you came so far! Most of the work seemed to be done!
I found a "how to" document on the web for GT Starlet conversions in a mini. I could send that to you if it helps re-motivate you!
I am keen to do one of these myself but am disheartened that i never get to see any finished projects
Zulu...
1967 mini Cooper S
