It is currently Fri Jul 18, 2025 12:29 pm
 Post subject: Mega jolt Leads
PostPosted: Fri Oct 15, 2010 9:14 pm
are the Ford leads that come with the mega jolt resistor type leads?
or should i be getting some resistor plugs.
will put some nice leads on it just want to start her up first and get her running on the mj.
PostPosted: Sat Oct 16, 2010 5:33 am
Yes, I'm still using the leads that came with the coil pack & EDIS I pinched off a Mondeo.
2008 Prado GXL
PostPosted: Sat Oct 16, 2010 1:34 pm
This space for rent
Fat Boy Dave wrote:
... I pinched off a Mondeo.
Did the owner notice? :shock:
PostPosted: Sat Oct 16, 2010 5:56 pm
from reading the megajolt forums, theres people who say "you have to use resistor leads", and others who say "I've been using non resistor leads for 1,000,000 years and no problems".
In my experience, trying between standard leads and the Ford resistor type leads, is there is no difference. But I only had a short period of testing the MJ before I broke something, and havent had a chance to fix it yet!
tim
PostPosted: Sat Oct 16, 2010 9:33 pm
what did you happened superseven mega jolt problems?
PostPosted: Sat Oct 16, 2010 11:05 pm
you don't have to use resistor leads/plugs.
you need a good EMI suppression, to protect your and other peoples stuff. no one wants to hear someones ignition system on the radio, or worse.
using resistor leads/plugs seems to be an easy and cheap way to achieve this.
i've never had any problems with non-resistor plugs and leads, i just make sure the EMI suppression is good enough
Rover 214 atm ....
