It is currently Wed Jul 23, 2025 10:03 am
 Post subject: Brakes
PostPosted: Sat Oct 16, 2010 7:47 am
On a Mini K, what does the T union close to the Brake M/Cyl bolt too I seem to be missing a bracket.
PostPosted: Sat Oct 16, 2010 8:03 am
Mods rock!
The Brass 'T' is the 'splitter' between the front and rear brakes. It is very important to re-fit the bracket holding the 'T' piece so the steel lines don't crack (then no brakes).
PostPosted: Sun Oct 17, 2010 1:13 pm
So is there a bracket that it bolts on to. Is there another bracket that comes off the fixed bracket that the clutch hose goes through.
PostPosted: Sun Oct 17, 2010 1:41 pm
he T Piece bolts to a Bracket which is then held in place by the Clutch pipe.
PostPosted: Tue Oct 19, 2010 10:20 am
Thanks. Seem to be missing that bracket. Have made one & all is good.Next question If the adjuster in the front backing plate is a little bit loose can you do anything with them or do you have to get another backing plate
Users browsing this forum: Steam and 91 guests
