It is currently Wed Jul 16, 2025 8:43 am
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 24  Next
PostPosted: Mon Oct 11, 2010 8:10 pm
Hi all .just a quick update
My mate Ashy and i started to finish off the last bits of painting
on the weekend
Heres the old fart Ashy hard at it sanding
And some pics of the bonnet and arches in primer
I had to repair the scoop insert as i had dropped it about a couple
of years ago
All going well i'll have them in color tomorrow
Gotta love daylight savings
Cheers Hallsey
PostPosted: Mon Oct 11, 2010 8:18 pm
hallsey wrote:
...Gotta love daylight savings...
I would if I didn't live in WA. grumble grumble grumble... bl00dy people voting it out. grumble grumble grumble. :evil:
-Alan
PostPosted: Tue Oct 19, 2010 2:55 am
God that looks familiar :shock:
Good work Hallsey - you are doing a damn fine job and very inspirational!!
Tricky
PostPosted: Tue Oct 19, 2010 6:08 pm
Ha ha yeah i bet it looks very familiar ol'sock
they'll both look better with paint on them :shock:
Cheers Hallsey
PostPosted: Tue Oct 19, 2010 6:57 pm
love that scoop. out there, yet sutle. nice :lol:
PostPosted: Tue Oct 19, 2010 10:32 pm
That scoop looks bloody awesome! Can you reveal what the front scoop part is from? Is it a Subaru Legacy? Apologies if this is posted earlier in this thread.
Answer the Question....
BUT always Question the Answer
PostPosted: Tue Oct 19, 2010 10:46 pm
Have a look at the bonnet of the half cut you got the engine from. I regret selling my bonnet now but ive got something different planned.
Simplify and add lightness
PostPosted: Tue Oct 19, 2010 11:11 pm
ahuh... I never got the bonnet as i bought the half cut already stripped - but should've recognised it from my owners manual! :oops:
PostPosted: Tue Oct 19, 2010 11:17 pm
I only remembered from Trickys build
PostPosted: Wed Oct 20, 2010 3:22 pm
Thanks Jester ,i like it too, not over the top and fuctional
and yes it's a EP82 scoop ,i've seen them on the starlet
website for $100--$150
Cheers Hallsey
PostPosted: Wed Oct 20, 2010 3:35 pm
I've got an EP82 bonnet if anyone wants it (I don't). I am more than prepared to cut out and around the scoop section. It would have to be shipped (from Perth).
-Alan
PostPosted: Wed Oct 20, 2010 5:34 pm
I've had a bit of a think about scoops, as i don't really want to put one on. I spoke to a guy in SA who is running the 4EFTE in a N/A body. I asked whether he has any problems without having air flow to the TMIC and he said he's had no issues whatsoever. So i'm considering not using one - anyone else had other experiences re: no scoop?
PostPosted: Wed Oct 20, 2010 6:00 pm
amos wrote:
...I asked whether he has any problems without having air flow to the TMIC and he said he's had no issues whatsoever.
I wonder whether he can back that up with eg intake temperature figures?(Air-to-Air) Intercoolers rely on reasonable air flow to greatly increase the efficiency in releasing the stored heat into the atmosphere, so I find it a bit hard to believe that a convoluted air flow path through the engine bay will provide the same cooling effect as a scoop that directs air straight onto the similarly positioned Top Mount intercooler. I expect that without a scoop, the intercooler would get heatsoaked much quicker and stablise at a higher temperature (at around what the average engine bay temperature is) rather than say, 5 degrees above ambient. It wouldn't cause problems, you just wouldn't produce as much power and the ECU would be doing things like retarding timing due to higher intake temperatures (thanks to the intake temperature sensor at the side of the intake plenum).
If you were to retain the TMIC with no scoop, at least give it some fresh air. As an example - the diesel Mazda3 has no scoop and a TMIC but has a dedicated (and sealed) air feed piping from the front of the car to the intercooler
-Alan
PostPosted: Thu Oct 21, 2010 8:01 pm
Yeah it made me wonder too. Particularly because the efficiency and power directly relate to the temp difference thanks to one of the fundamental laws of Thermo.
I was thinking at least the bonnet is easy to modify after the project is finished if need be. Probably trial without it and see what happens. Could do the calcs but can't be arsed!
PostPosted: Fri Oct 22, 2010 3:25 pm
Yes, true.
But mine feeds the oil cooler, which sits in the place of the top-mount.
The I/C is now a front mount with automatic water spray (or will that be water/methanol injection, hmmm...)
Tricky
