It is currently Fri Jul 25, 2025 5:55 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Apr 02, 2005 11:11 am
Stuartminidlx wrote:
1) MSG20 - GEARBOX 4 SYNC REBUILD KIT LESS DIFF PRE A PLUS 14MM MAINS 1 £85.17
2)C-AHT54 - PIPE,HITECH CENTRAL OIL PICKUP PIPE 1 £22.50
3)C-AJJ4032 - GEAR KIT 22G1371/22G1040 ONLY TO CONVERT TO "S"RATIO 1 £82.55
4) C-BTA166 - DIFFERENTIAL PIN UPGRADE (SEE C-BTA167 ALSO) 1 £13.00
there they are sorry i have been abit busy
stuart
thanks stuart. :wink:
PostPosted: Sat Apr 02, 2005 12:30 pm
Stuart, I wouldn't bother with straight cut CW/P for a road car. Too noisy. :cry:
I don't believe the stock diff gears are weak, those I've seen break resulted from either other gearbox bits going thru them due to failure, or accidental chipping of the pinion during assembly of the lockwasher.
PostPosted: Sat Apr 02, 2005 11:01 pm
OK,
So I'm well advanced on stripping the gearbox. Got the diff housing off and the diff out, plus the oil pickup and input shaft and laygears (although it's back in temporarily).
Found the rest of the shrapnel floating around the bottom - it had AUB5040 stamped on it. Doesn't appear to be a mini item :shock:
What's the best way to lock the output shaft to undo the nuts either end?
I've tried a few different ways and can't seem to find a suitable way.
Anyone got any ideas?
KB
PostPosted: Sat Apr 02, 2005 11:09 pm
Bring it over and I'll do it for you in 5 mins.. :lol:
Basically you need to lock it in 2 gears. USE 1ST& 4TH.
You do this by removing the shift shaft's detent sleeve, then rotating the shaft anti clockwise? until it clears the shifter forks. Then use a screwdriver to move the synchro sleeves into 1st gear and 4th gear.
I then put it on the ground and apply the weight of my boat trailer to it via a block of 4x3 hardwood. Pinion nut is done up to 150 lb/ft so takes some undoing.
?? Easier to bring it over here isn't it.. :lol:
PostPosted: Sat Apr 02, 2005 11:30 pm
Yeah, specially when I don't have a boat! :D
No wonder I couldn't do it on my own on the bench.
Cheers Doc - got family stuff on tomorrow, so I'll PM or ring you about it.
I've got a friend in the UK at present who can go to Minispares for me, so I'm keen to see what it needs before he comes back.
KB
PostPosted: Sun Apr 03, 2005 9:38 pm
I've checked my laygear and the bearing area looks ok but the middle seems fairly well grooved.Is this normal and if not should I start looking for a replacement.?
PostPosted: Sun Apr 03, 2005 9:55 pm
LOL - here's one I perpared earlier
ps - thanks Doc nice tip came in real handy today.
PostPosted: Sun Apr 03, 2005 9:57 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
geez who i thought you were older :)
makka
PostPosted: Sun Apr 03, 2005 10:03 pm
Whodat working on his gearbox :lol:
Yes the pinion nut is a real bastard. I spent probably 20 mins undoing mine solo with a very long metal bar over the end of a breaker bar and standing on the casing which was gclamped to a wooden plynth... should have put it on video and sent it to that 'australias funniest home video show' show.
The big double row bearing in the rod 'box i stripped had a ball missing :shock: and i never found it anywhere. Watch the syncro housings as you drift the main bearing out- i didnt realise the 1st/2nd hub on mine was separating and the 3 balls went everywhere.
PostPosted: Sun Apr 03, 2005 10:18 pm
Christoph wrote:
watch the syncro housings as you drift the main bearing out- i didnt realise the 1st/2nd hub on mine was separating and the 3 balls went everywhere.
If it's a remote change box or earlier, pull the selector shaft detent springs out first. 2 plugs in back of box near sump plug. :wink:
PostPosted: Mon Apr 04, 2005 7:46 am
stuart
Doc - can you confirm that these are the right numbers to get for my rod change box?
My friend in the Uk can get them, but he needs to do it in the next few days if so.
PostPosted: Mon Apr 04, 2005 8:02 am
Yes Kev, they are right for your box. :wink:
PostPosted: Tue Apr 05, 2005 10:57 pm
GEARBOX,4SYNC REBUILD KIT INC DIFF PRE A PLUS 14MM MAINSHAFT £119.66
PRESSURE PLATE DIAPHRAGM CLUTCH TYPE PRE VERTO £15.58
CLUTCH DIAPHRAGM GREY COMPETITION TYPE £26.96
CLUTCH PLATE ROAD AND FAST ROAD / [ HB8017 ] £13.05
FLYWHEEL STEEL ROAD/RALLY INERTIA STARTER £90.00
PIPE,HITECH CENTRAL OIL PICKUP PIPE £22.50
3.647 crownwheel and pinion $70aus
have i forgoten anything
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Tue Apr 05, 2005 11:01 pm
Id forget the grey diaphragm, orange one is plenty strong. All the grey will do is wear out the thrust washers faster.. :shock:
Even a blue Cooper S one is OK, I ran one in my 1310 (110HP @ crank approx) for years and it never slipped. :wink:
Users browsing this forum: No registered users and 50 guests
