It is currently Tue Jul 22, 2025 12:34 pm
 Post subject: Proportioning valves??
PostPosted: Sun Apr 03, 2005 8:23 pm
ok im at the stage where ive got 3m of new steel brake pipe rolled up in my room, well i went down to the wreckers and chopped some brake pipes off a few cars down there, and bent them to shape, only from MS to booster, and back to dual circuit proportioning valve.. and today i bent and cut the new stuff.. :)
now im a bit confused, i have the standard later? type prop valve on the rear subframe, now with the dual circuit prop valve in the engine bay, do i need to remove the rear valve and put a T peice in there?? and will i have to change the rear wheel cylinders?
i cant see running 2 prop valves is normal :?
thanks :D
GTi Turbo'd mini, abused daily
PostPosted: Sun Apr 03, 2005 9:04 pm
Forget the proportioning valve in the engine bay, stick with the std prop valve on the rear subframe. Do your brake pipes to suit.
Steve
PostPosted: Sun Apr 03, 2005 10:05 pm
i just spent $260 getting it reconditioned, its going in :)
ditch the rear prop valve? anyone? :oops:
PostPosted: Sun Apr 03, 2005 10:31 pm
Barney is running a dual system from a Clubbie, just has a brass tee on rear subby where the rear limiting valve usually is. :wink:
PostPosted: Sun Apr 03, 2005 10:35 pm
T piece from the front section to the two rear's.
I was thinking today with the Dual Cuircits..Can you put a Bais control in the system :idea:
