It is currently Tue Jul 22, 2025 2:51 am
PostPosted: Wed Oct 27, 2010 9:37 pm
Tomboss Breweros
I've seen a few good smashed engines at work but never busted one of my own.
Back to the 1100 crank,
Mines a 1100 and it revvs to 7000, i've been told they break about there.
Mines been crack tested and balanced so i suppose that helps.
Is the cause of that one in the pic breaking known?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Oct 27, 2010 10:01 pm
Usually a fatigue crack in a 1098 or 1275 crank starts from one of the big end journal's fillet radii.
It's most important when regrinding them that the radius is kept as big and smooth as possible.
It's a bit hard to tell from that pic but it does look a typical failure.
To improve fatigue life we used to mask up all the journals up then shot peen the crank webs and fillet radii, back in the 70s.
Here's a couple of pics of what happens to a gearbox when a bushfire goes through your Mini shed.. sorry I can't get the 2 pics to post but the links work.
http://home.exetel.com.au/zoomini/zoomi ... 718-40.JPG
http://home.exetel.com.au/zoomini/zoomi ... 719-40.JPG
PostPosted: Fri Oct 29, 2010 10:12 pm
GT mowog wrote:
Perhaps not as spectacular as some above, but
I see you had Photoshop Version .001
PostPosted: Fri Oct 29, 2010 11:41 pm
1275 flat chat down back straight, bit undergeared, a bit over revved.
Cross flow ventilated gearbox, new design.
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Sat Oct 30, 2010 6:05 pm
Here is my effort
Since found that it also put a small crack I'm the block .... Grrr another 1275 block
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sun Oct 31, 2010 1:30 am
I'v got 1 also
PostPosted: Sun Oct 31, 2010 8:10 am
I managed a set of bent conrods in a Magna V6 (work car) in a Harvey Norman car park in a rain storm, just drove thru a small dip and it stopped, water had splashed over the bumber and into the intake.
Slightly off the topic
Customer towed in a late model BMW a week ago because they drove it into flood water.
So we took the plugs out and started trying to turn it over, but it wouldn't budge, so we jacked it up and oil started running out
There is a hole big enough for my hand to fit through in the side of the block.
So remember peoples, if your not sure wether its low enough to drive through, don't try it! Especially if you own a nice expensive BM
Back on topic,
why so many broken cranks? Just plain abuse?
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Sun Oct 31, 2010 9:03 am
old age... fatigue,,, ecxessive high rev abuse.... poor harminic balncer condition,,, i can go on & on
most crack right through the oil hole & edge of journal (as all the photos are showing) ...on the edge of sharp fillet,,, that`s why newer (less fatigued) cranks with large/broader fillets are far better
PostPosted: Sun Oct 31, 2010 12:12 pm
Good stuff guys!
I've never broken a crank, I'm a bit more gentle than that. I've only ever destroyed a diff pinion (car still worked ok though) and took a whole bunch of teeth off an idler gear (once again car still worked fine, if a little noisy).
