It is currently Fri Jul 25, 2025 10:28 pm
PostPosted: Fri Oct 29, 2010 6:22 am
DTrain wrote:
how does having having two restrictions equate to having more power than one?
Maybe it hasn't got the power to cope with a fully sik 4"cannon straight through, and likes a bit of back pressure?
PostPosted: Fri Oct 29, 2010 8:57 am
mattsmadmini wrote:
now the next part... do i weld the bottom of the manifold to the connecting middle pipe or clamp the beh-jesus out of it?
Clamp and use exhaust manifold sealant, and shed loads of it. If you weld it it will never come off ever again! I welded my Y piece to the 2" exhaust pipe section though cause it hangs way too low to have a clamp.
My preference is to have a 2 box because it's just excessively loud with single box.
As for performance, there's no difference at all since the hot dog that goes before the muffler is a straight through type, 2" all the way through. Can't see how this would hinder gas flow... Important to look at the mufflers you are buying carefully
PostPosted: Fri Oct 29, 2010 8:49 pm
pipe size remaining constant so same amount of back pressure. i understand the difference would be miniscule but i dont understand how you can gain power
PostPosted: Fri Oct 29, 2010 8:55 pm
I've never had a twin box RC40 you know, but I wouldn't mind giving it a try...
Can you buy the RC40s center box seperate to the full systems?
Are they made such that if you cut a sufficient gap in the pipe, that the center boxes just slip on?
PostPosted: Fri Oct 29, 2010 9:43 pm
OK, Me blonde. Is there more grunt with one or two RC 40's?
PostPosted: Fri Oct 29, 2010 10:09 pm
When my RC40 died I got the local exhaust shop to put a larger and baffled aftermarket muffler in. It made it quieter and the wife is much happier about the noise. Cost $120 fitted. Good value methinks.
Alec
PostPosted: Sat Oct 30, 2010 8:56 pm
It is well documented in the UK the twins give you better power than the single. I have the Calver report here somewhere.
Don't know how, it just does(and is quieter too!) :D
Rob Forsyth
Miniot!!
PostPosted: Sat Oct 30, 2010 8:59 pm
"How loud is loud?...." single box RC40 is illegal in the ACT - as one of our club members found out.
Can you buy the pieces separately?? Yes, at Minispares - especially when you ask for a hacksaw to separate the twin box unit they'e trying to sell you.
Cheers, Ian
PostPosted: Sat Oct 30, 2010 9:05 pm
Single box RC40 is only about as loud as the original Cooper S was. :wink:
PostPosted: Sun Oct 31, 2010 7:33 am
Mods rock!
Cheers, Ian
How loud it is depends on a few other factors - especially engine spec - apart from the muffler.
