It is currently Sat Jul 26, 2025 1:15 am
PostPosted: Sat Oct 30, 2010 12:57 pm
does anyone know what size thread this pesky little thing is?
it appears the nipple that goes into the head for the coolant bypass is so corroded on mine, i cannot get enough purchase on it with a hose clamp...
i don't like my fancy new red coolant on the floor
i know it's a contentious issue whether to plug this or not. i'm thinking i'll plug it.
so what size thread is it?
should i use brass or steel plug? does it matter?
cheers.
PostPosted: Sat Oct 30, 2010 3:27 pm
Mods rock!
cheers.
5/8" UNF. I use steel plugs but I also use a good coolant / inhibitor.
PostPosted: Sat Oct 30, 2010 5:52 pm
I make DrMini ST brass adaptors. Never rust out like the originals do. 8)
However if plugging it off, a steel plug will work fine.
PostPosted: Sat Oct 30, 2010 6:35 pm
hmmm, i've been wanting some DrMini porn parts on my car for a while now.... :lol:
Doc, how long is the "barb" for want of a better term, or smooth nipple, on your adaptors?
i'm trying to use a wide clamp on a kevlar hose but my old adaptor does not have enough left in it for the clamp to grab on to....
Doc are yours barbed or have a 'bead' on the end?
PostPosted: Sat Oct 30, 2010 6:44 pm
Mine are straight, no barbs, I turn them from a BOC gases oxy hose joining nipple. I've never had a leak problem with std rubber 1/2" radiator hose on there.
Length of the straight bit (guess) is around 1/2".
PostPosted: Sat Oct 30, 2010 6:46 pm
hmm i like the idea of using radiator/heater hose, why'd i not think of that before...
pm sent.
