It is currently Fri Aug 08, 2025 8:15 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 189, 190, 191, 192, 193, 194, 195 ... 568  Next
PostPosted: Sat Nov 06, 2010 8:07 pm
Played with the toy car today:- Fitted the new fuel balance pipe and associated braided hoses. Didn't go straight in as I hoped, but luckily had the original (very ill) available to check angles... Fitted new fuel pump and hoses.... Fitted "T bolt" - it is responsible for canceling the indicators - all good.
Getting there, slowly slowly....Plenty of time....Don't you worry about that....
No decision is incorrect when made - but it does become apparent in retrospect...
PostPosted: Sat Nov 06, 2010 8:33 pm
refitted Sues Exhaust but it will need to be replaced
other than a few thing I also layed the carpet in the Van..I don't think My old man had Carpet In his Vans :lol:
PostPosted: Sun Nov 07, 2010 12:41 pm
Finish off heaps of stuff - replaced all clevis pins and clutch arm, bled clutch and refreshed fluid.
Oil change after a quick run to Repco for the LAST oil filter in stock - lucky me.
Tried to balance the carbs and the frigging Carbalancer doesn't fit over the carby as the air filter housing bolt too long, so adapted a funnel to give clearance. THEN found the ball in the air tube was missing...... :x , so made a couple of epoxy stick putty and got it working. Then hit it with the colourtune and had to lean it right out as was so rich......
Took it for a test drive,...sweeet! Gears very rarely crunch now, and the car wants to go so much faster! Also noticed no smoke at all during normal driving and start-up, and reduced on the over-run.....
Now to fit Wombat's voltage regulator........
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Nov 07, 2010 4:14 pm
gave it it's yearly bath
PostPosted: Sun Nov 07, 2010 4:26 pm
Online
Made up a jigger to let me check idler gear endfloat with both the engine and flywheel housing on.. :wink:
PostPosted: Sun Nov 07, 2010 5:12 pm
Stripped the paint and glue from around inside the roof of the 1275LS project and then etch primed. Stripped the paint and glue from the rear side bins. Stripped the paint off the new bonnet. Stripped the paint off the new guards and front apron.
Getting closer to the paint shop....... :) :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Nov 07, 2010 7:49 pm
Carpet In
Seats In
Stereo In
Seat Belts On
Door Card On
Binnical On
Volt Meter sorted:roll:
Grill On
Bonnet On
Maybe 5 thing left and she'll be On the road...Not Perfect but thats the adjustments afterwards
PostPosted: Sun Nov 07, 2010 7:56 pm
Got a set of Yoke A008's,
removed the drivers side calliper, rotor, hub and drive shaft,
cleaned the grease out of the CV,
broke the cir-clip on the end of the drive shaft,
Gave up and went out for a drive in the P76.
PostPosted: Thu Nov 18, 2010 12:00 am
new top radiator hose (Tuesday, after dad split it on the drive home from the PO's Place).
Played with the timing a little and mixture.
pulled apart distributors and then put them back together.
Drove it to the beach.
thought about tyres and wheel combo's.
went hunting through books and boxes to see what I needed for my project.
MINE:
1976 Clubby 1100, 266 Kent cam, slightly worked head. (awaiting paint)
1978 1275LS Hi-Ho Silver with a Camtech 619 cam and some strange looking rockers
PostPosted: Thu Nov 18, 2010 12:15 am
i ordered $1800 clams worth of paint. at TRADE price :oops:
this van better look pretty :D :P
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Nov 18, 2010 2:42 pm
replaced my blown coil with a gt40 one and have neatened up the wiring in the engine bay with split conduit 8)
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Thu Nov 18, 2010 8:39 pm
Ported the head for the Cooper's new engine.
I used Vizard's book and a little of Des Hammil for reference, motive power provided by supercrap and sutton tools :P.
Today was the ports, tomorrow I'll do the chambers.
PostPosted: Thu Nov 18, 2010 8:43 pm
Online
Don't do much at all to those chambers, just de-dag em. These 295 ones are too damned big to begin with. 998 Cooper had D top pistons to fill em up a bit. Even with flat top pistons in a 998 with this head (stock thickness), C/R is too low.
PostPosted: Thu Nov 18, 2010 8:51 pm
Yeah, thats pretty much what I had in mind. I will skim it a little however if required to get the compression ratio where I want it. Even Vizard touches the chambers only marginally.
PostPosted: Fri Nov 19, 2010 10:05 am
Continued fabricating a new skin for my door from scratch - just too many dents in the old one, some brass in there too! I love my TAFE teacher - he knows old school techniques :D
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
Users browsing this forum: drmini in aust and 87 guests
