It is currently Sun Aug 10, 2025 7:07 pm
PostPosted: Mon Nov 15, 2010 10:55 am
Hey,
Ive noticed when i apply the brake and start to slow down i get a clicking noise. Not sure if its coming from back or front. i was wondering if anyone knew what this meant? I was told possibly could be wheel bearings but jsut thought id ask.
Thanks Blake
PostPosted: Mon Nov 15, 2010 11:32 am
a few things come to mind..
wheel bearings
pads moving in the caliper (I had this once, pissed me off to no end and it was a clicking noise, however have no fixed that :) )
Crap on the disc and pads clicking away
Do you have discs on the front?
PostPosted: Mon Nov 15, 2010 1:00 pm
thanks for the reply.
yeh i have discs on the front. It was after a day on the skid pan.
How do i tell if the bearings are stuffed?
PostPosted: Mon Nov 15, 2010 4:00 pm
double post :oops:
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Nov 15, 2010 4:02 pm
Jack the car up, grab the wheel and shake it. Check for any movement.
- Look to see where the movement is:
- Hub
- Ball joints
- Tie rod ends etc
If its the hub its likely to be the bearings. Its an easy enough job to change them.
If it was after a day on the skid pan, my money would be on the bearings, because you are putting a lot of sideways force on them.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Nov 15, 2010 4:12 pm
probly a silly question but, do you have a brake pedal switch instead of the pressure one? could just be the switch clicking as its activated
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Mon Nov 15, 2010 4:14 pm
thanks i'll jack the car up and see what i come up with!
Um reply to the switch question, it clicks several times from about 20k's down to a complete stop
PostPosted: Mon Nov 15, 2010 6:13 pm
My car did that `clicking' during low speed braking, after changing pads and checking everything else I found one disc rotor was cracked through... :shock:
So, I fitted a new pair.
PostPosted: Mon Nov 15, 2010 8:07 pm
mmmm maybe an excuse to give my other half to convince her i should repair/upgrade my brakes!!!
PostPosted: Sat Nov 27, 2010 9:08 pm
worked out what it was! The brakes just needed a clean after the skid pan its all good now!
Users browsing this forum: No registered users and 181 guests
