It is currently Tue Jul 29, 2025 3:59 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: clubby GT cluster
PostPosted: Tue Nov 16, 2010 8:13 pm
Hey all.
Can anyone here tell me if a early 70s leyland clubman gt 3pod instrument cluster will fit in my 76 clubby also with a 3pod cluster? I ask as there is one on ebay atm :P
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Tue Nov 16, 2010 8:20 pm
No, no difference in fit , the printed circuit board might be different , there was someone on Ausmini making replacements , from memory the GT tacho goes round to 8,000 and the Mini S ( 1100 ) went round to 7,000
PostPosted: Tue Nov 16, 2010 8:23 pm
yea tacho goes to 8000 and speedo goes to 120 mph
PostPosted: Tue Nov 16, 2010 8:40 pm
One thing to be careful of from memory is the speedo cable. The real early cables screwed on, the late models "clipped" on. No great drama if you're prepared to change the cable if necessary.
PostPosted: Tue Nov 16, 2010 8:42 pm
The one on ebay is WRONG!!! GT ones redline at 6500 where as clubman ones redlined at 5500.
Just trying to milk all he can from it.
Yes and early clubmans had screw speedo cable and later leyland mins had clip on.
PostPosted: Tue Nov 16, 2010 8:46 pm
ahk so dont worry about it then if its not a real gt one then ay
PostPosted: Tue Nov 16, 2010 8:52 pm
I had to sit at an angle for the flash glare, mine goes to 8000, 74 Mini Clubman S 1100, and here I was saying it only went to 7000 and its my car
:oops:
PostPosted: Tue Nov 16, 2010 8:54 pm
Supercharged
speedo is the same as GT, tacho isnt.
there's two on there
http://cgi.ebay.com.au/Mini-Clubman-GT-Leyland-3-pod-tacho-dash-/260693239886?pt=AU_Car_Parts_Accessories&hash=item3cb287284e
http://cgi.ebay.com.au/leyland-mini-triple-guage-panel-/110608618995?pt=AU_Car_Parts_Accessories&hash=item19c0c995f3
PostPosted: Tue Nov 16, 2010 8:58 pm
it was the first link that i found. ok im not gonna get either if theyre not correct gt then
PostPosted: Tue Nov 16, 2010 8:59 pm
subwayseth wrote:
and neither of them are GT
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue Nov 16, 2010 9:01 pm
Yeah snail i dont recall there being a difference in the uppermost rev limit.
What it is supposed to look like:
ALthough i did think the speedos between clubman and Gt was different. But going by Snalls they mustn be. I thought they maxed out at different speeds
GTmowog will know when he sees this.
But those speedos came in other cars as well (i think the marina)
PostPosted: Tue Nov 16, 2010 9:10 pm
Isnt the roundie speedos that differ, where as clubby speedos are all the same?
You're so square
Baby I don't care
PostPosted: Tue Nov 16, 2010 9:11 pm
it's the red line that is different.
PostPosted: Tue Nov 16, 2010 9:13 pm
There were a few different diff ratios used so not all the same inside the speedo head.
1098/remote box had a 3.647 diff, the 998/rodchange box had a 3.44.
Oz Clubby GT was a 3.44 also.
