DartzMan wrote:
After everyones advice..
I am painting the shell shortly..
Would you advise painting the inside, masking up then painting the outside, or could I just paint the inside and continue on with the outside same day without masking up the inside..
I am painting all one colour acrylic Lacquer
With Solid colours (this applies to acrylic only) you don't need to mask off sections after you're done. You can just move on.
As Mick said, I'd do the interior or underside first.
Remember the correct order too, edges and corners first, then fill in.. starting from bottom to top... (obviously section at a time)
<edit> once the inside, underside and roof are painted, try and hit the rest in one go...
<edit 2> I'll try and dig up my a pircture from my tafe notes that shows you how too tackle it...
<edit 3>
Found that picture I was talkin about... I'll try and scan it at work for you tomorrow.... This is basically what it shows you... but instead of a crude finger painting of a box, it has a whole car and all its panels, showing where to start and stop etc...
<edit 4>......................... nah just screwing with ya... was starting to look funny
