It is currently Mon Aug 18, 2025 6:41 am
 Post subject: Engine breathing
PostPosted: Tue Nov 23, 2010 11:03 am
I'm putting a maniflow twin su inlet manifold on the stroker it has no provisons to use S type pcv valve do I put in a fitting, convert to ccv or use a normal tappet cover with the breather on it
PostPosted: Tue Nov 23, 2010 12:31 pm
I'd tap it for a PCV... but CCV would be easiest - I don't like venting to the engine bay cos it smells
PostPosted: Tue Nov 23, 2010 1:07 pm
It is there steel manifold it needs a fitting welding on
PostPosted: Tue Nov 23, 2010 3:13 pm
If the carbys have the breather inlet tubes on them why don't you just use CCV? The plastic Y piece is inexpensive, as is the rubber tube.
Users browsing this forum: No registered users and 314 guests
