It is currently Tue Jul 22, 2025 7:54 am
 Post subject: Oil Leaks
PostPosted: Tue Apr 05, 2005 1:45 pm
hi guys, it appears that i have found a cause to the smokyness of my car.
I have noticed a oil leak at the back of the engine where between the cracks, i am seeing some oil leaking out and i am also now leaking oil under the rocker cover.
Does anyone know of a quick fix this possible is a seals must be old.
DAMN THIS OIL LEAK.
Jet Red Mini K
PostPosted: Tue Apr 05, 2005 1:51 pm
New rocker cover gasket, $20??
Make sure the rocker cover bolts are tight, I found mine were loose when I checked last time :shock:
Where at the back of the engine? between what cracks???
 Post subject: Re: Oil Leaks
PostPosted: Tue Apr 05, 2005 1:56 pm
not sure where youre talking about
but yeh for the rocker cover section get a new gasket with a nice thick rubbery goo (in a tube)
Inconspicuously Conspicuous
PostPosted: Tue Apr 05, 2005 1:59 pm
Ahh i must soo be confusing.
it appears to be under the engine head, and under the rocker cover.
Jet Red Mini K
PostPosted: Tue Apr 05, 2005 2:40 pm
Under the rocker cover = Easy to fix and probably not a big issue
Under the head = Not too sure about this... it could be big problems!
Are you 100% sure it's not just leaking from the rocker cover and dripping all the way down to the head and bellow? I would 1) Check that the rocker cover bolts are done up tight 2) replace the rocker cover gasket (cheap and easy to do) and see if still leaks
PostPosted: Tue Apr 05, 2005 2:45 pm
Are you sure it's the rocker cover that is leaking? Do you have a breather on the top of your rocker cover? could the oil be coming from that??
PostPosted: Tue Apr 05, 2005 3:02 pm
Maybe by "Rocker Cover" you mean "Tappet Cover" or "Tappet Chest" ?
Rocker cover = Top of engine with the oil cap in it
Tappet Chest = Bits on the back of an 850/998/1100 or Cooper "S engine that bolt on with a single bolt each.....
Hope this helps
J
PostPosted: Tue Apr 05, 2005 3:07 pm
oooohhhh......tappet chest..... :lol: haven't heard it called that.
I was thinking it might be leaking oil from there too. Keep that one in mind Adam.
PostPosted: Tue Apr 05, 2005 3:17 pm
ive called it engine plates, back plates, tappet covers
i like "tappet chest" though
so this oil leak in the front
causes smokiness?
PostPosted: Tue Apr 05, 2005 3:19 pm
I Like a nice chest.....
:oops:
J
PostPosted: Tue Apr 05, 2005 3:23 pm
:lol:
PostPosted: Tue Apr 05, 2005 7:41 pm
Can say im 100% sure but its due for a service so i will get it all checked out during the service.
Jet Red Mini K
PostPosted: Tue Apr 05, 2005 7:43 pm
there is a deffinate leak under the rocker cover, definately see oil leaking out. at front but can't see at the back all that well.
Jet Red Mini K
PostPosted: Wed Apr 06, 2005 1:07 am
i always called them inspection plates??? mine were leaking heaps badly on viv b4 the new motor went in :D
Users browsing this forum: Barkfast and 77 guests
