It is currently Tue Aug 19, 2025 2:25 pm
 Post subject: What head is this?
PostPosted: Wed Nov 24, 2010 7:34 pm
I understand this is a MK II S cylinder head. Does that look right?
What sort of work has been done to the chambers - minor or significant?
What are the numbers stamped on the end?
PostPosted: Wed Nov 24, 2010 7:51 pm
Well it's a 12G940 head casting by the shape, might be a Mk2 S. Valve sizes look about right. Chambers have been cleaned up a little. Inlet ports look cleaned out near the valves.
Does it have 12G1805 stamped near the thermo housing (1/8 letters)?
Not all Mk2Ss did...
PostPosted: Wed Nov 24, 2010 7:57 pm
Keith Calver says
" A+ heads generally have three collet grooves in the valves, collets are 14-degree cone taper instead of the 10-degree on single groove collets (so parts are not interchangeable between single and triple groove types) and the top-caps have a raised ridge around the collet hole "
PostPosted: Wed Nov 24, 2010 7:58 pm
This is not a A+ head from the pics, it's flat on top all round the thermo housing.
PostPosted: Wed Nov 24, 2010 8:20 pm
No, nothing stamped in that area.
I'm assuming the stamping on the end of the head near the heater outlet was done by whoever worked on it. It appears to have been chemically dipped or blasted to remove all the paint and grime.
I got from eBay user fat850. Is he on here?
PostPosted: Wed Nov 24, 2010 8:24 pm
Obviously I was reading the wrong section the article :)
Did the head stamping change when they started on the GT :?
PostPosted: Thu Nov 25, 2010 4:47 pm
can you post a pic of the thermo end
PostPosted: Thu Nov 25, 2010 7:14 pm
Like this, or from above?
PostPosted: Thu Nov 25, 2010 7:19 pm
from above please
PostPosted: Thu Nov 25, 2010 8:06 pm
PostPosted: Thu Nov 25, 2010 8:14 pm
It looks like its possibly a Mk2 S / Clubman GT head as the casting indent next to the therom housing is the same as my S engine
Measure the valves that may also help
Hope this helps
Kiwiinwgtn
PostPosted: Thu Nov 25, 2010 8:15 pm
Thanks everyone, much appreciated.
Users browsing this forum: No registered users and 451 guests
