It is currently Sun Aug 03, 2025 7:04 pm
PostPosted: Sun Nov 28, 2010 12:34 pm
I have just fitted new cork side cover gaskets and did them up quite tight but it now looks like they are leaking. A mate told me that they can leak if over-tightened, is this correct?
PostPosted: Sun Nov 28, 2010 1:29 pm
Hi,
That is correct. If you do make it too tight, gasket moves and starts leaking.
do just a finger tight and bit more. No pressure there so no need to make it tight.
Since light travels faster than sound, people appear bright until you hear them speak
PostPosted: Sun Nov 28, 2010 3:35 pm
Oops :oops:
I have already over-tightened them, do I need to buy new seals?
PostPosted: Sun Nov 28, 2010 4:26 pm
Mods rock!
Yes. See if you can find the red 'rubber' ones. They are about, but not many places stock them.
PostPosted: Sun Nov 28, 2010 5:48 pm
Are you sure they are not leaking from around the bolt? Early ones have a red fibre washer there, the later (dished in) covers have a square section rubber ring inside a special retainer washer instead.
