It is currently Fri Aug 01, 2025 11:26 pm
 Post subject: lights out
PostPosted: Tue Nov 23, 2010 11:28 pm
minimuts out driving in the new 1275LS beast tonight and the lights went out (almost predictable).
Fuses OK - even changed them.
Any thoughts on the source of the problem?
PostPosted: Wed Nov 24, 2010 5:43 am
Mods rock!
I have had a number of the Headlight / parker switches fail and without warning.
 Post subject: Lights fault
PostPosted: Wed Nov 24, 2010 6:29 am
Check if the parkers still work, then see if you have an output on the blue wire to the dip switch then see if there is power coming out of the dip switch from the blue/red when on low beam and Blue/ white on high beam. If there is nothing coming out of the rocker switch you can carefully pull it apart and clean the contacts. But if after doing so the fault is cleared I would suggest fitting headlight relays to take the main headlight load away from the switches. And you will end up with better lights too.
"Let us remove your "SHORTS"
PostPosted: Wed Nov 24, 2010 8:54 am
No tail lights or interior lights.
Engine still starts & have indicator lights.
Will get minimuts to work checking where the power is/isnt.
 Post subject: No lights
PostPosted: Thu Nov 25, 2010 5:55 am
Check your Main power Fuse.
 Post subject: Re: No lights
PostPosted: Thu Nov 25, 2010 6:49 pm
That was the first thing we did.
MINE:
1976 Clubby 1100, 266 Kent cam, slightly worked head. (awaiting paint)
1978 1275LS Hi-Ho Silver with a Camtech 619 cam and some strange looking rockers
PostPosted: Thu Nov 25, 2010 11:22 pm
My 1275LS was doing the same thing until recently. Check the 15 amp inline fuse on the middle of the firewall.
Also, the problem has disappeared since the relays were installed and as Tony says, the lights are now heaps better. No need for H4's.
Alec
PostPosted: Fri Nov 26, 2010 4:51 pm
interior light, brake lights and indicators work. no parkers or speedo surrounding light tho.
MINE:
PostPosted: Fri Nov 26, 2010 8:12 pm
Those are the exact same symptoms mine had.
Fuse.
Relays.
Circuit board on cluster.
No more problems. :D
Alec
PostPosted: Sun Nov 28, 2010 9:54 pm
pulled light switch and cleaned up contacts - no change.
no in-line fuse (there is on the project clubman, but not the LS)
it has relays.
figuring minimuts might visit the auto-elecs tomorrow
(electricals not my thing)
