It is currently Wed Aug 20, 2025 7:35 am
 Post subject: Wipers
PostPosted: Mon Nov 29, 2010 7:04 pm
I haven't got much to go in getting Marcia on the Road but the Wipers just arn't fitting for me. Do you assemble the Box Assembly with the Tube & Cable with the Motor and Fit. I have also tried with the Motor in place and trying to connect the Cable but the Tube & retainer bolt arnt long enough.
Also struggling to get the passenger side angled enough to tighten down the nut.
Any Hints will make me a Happy Man
PostPosted: Mon Nov 29, 2010 7:49 pm
it's a 68 or earlier, do you have the right wiper motor (square) and wheel boxes too?
PostPosted: Mon Nov 29, 2010 7:53 pm
DONT KNOW IF THIS HELPS BUT WHAN I REPLACED MY MOTER I LEFT THE CABLE IN PLACE ,,i just pulled the motor apart (took the cover off)then inserted the cable then bolted every thing together again
PostPosted: Mon Nov 29, 2010 8:04 pm
Yep Square Motor (Two pinned) & believe the wheel boxes are correct as its the only ones I have. Thinking the tube that connect to the motor maybe bent a little. I'm also using your Top Rubbers Dr with similar bottom but smaller diameter
PostPosted: Mon Nov 29, 2010 8:38 pm
I've always had to fit it all up loose, usually putting the tube/wiper boxes in first, then the motor but not bolted in until I connect it to the tube/cable, then I jiggle everything around until I can bolt the wiper motor up.
I tried fitting a whole assembly without taking anything apart or loosening anything. I think I invented new swear words that day :/
Jacob
PostPosted: Tue Nov 30, 2010 12:30 pm
Jacob
would have to agree here.. same has happened to me :oops:
PostPosted: Tue Nov 30, 2010 10:05 pm
hee hee :-)
PostPosted: Tue Nov 30, 2010 10:18 pm
Yep did try that also...but didn't get a chance to try it again tonight...ill give the tube a bend tomorrow and see how it goes
PostPosted: Tue Dec 07, 2010 7:26 pm
Well..I decided this afternoon I was going to look at the wipers.
Owen off to bed..Okay lets get started..Wiper box & tubs already out and just sat there looking at it. Hmmmm I wonder if I put the Wiper Box up the otherway the Pipe would be closer
Well You would not credit it..I rebuilt them up the wrong way :lol:
PostPosted: Tue Dec 07, 2010 7:27 pm
ROFLMAO! :lol:
PostPosted: Tue Dec 07, 2010 7:30 pm
:lol: Glad you got it sorted in the end.
PostPosted: Tue Dec 07, 2010 7:32 pm
Mods rock!
Don't swap it. They'll work better backwards!
Nice to see your getting on top of yr Rippers....errrrr.......wipers :lol:
PostPosted: Tue Dec 07, 2010 7:37 pm
What a wee Ripper...I did have to have a laugh at my own expense
Specially after today dummy spits but the day has ended up on a positive note
PostPosted: Tue Dec 07, 2010 7:58 pm
NAV-MAN
The important part is that you can sit back and laugh.
PostPosted: Tue Dec 07, 2010 8:01 pm
:lol:
I thought I was the only one who did that! (see my sig ↓↓)
Jacob
Users browsing this forum: Bing [Bot] and 375 guests
