It is currently Wed Aug 20, 2025 6:51 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Nov 29, 2010 6:31 pm
In Australia I suppose you could split the different types into a set of groups to show when the main changes model occurred.
61-65, Morris 850, Morris Cooper. (assembled from CKD kits.)
65-69, Morris Mini Deluxe, Morris Mini Minor, Morris Cooper S. (locally made.)
69-71, Morris Mini 1100 "K", Morris Mini 1100, Morris Cooper S Mk2. (locally made.)
71-73, Mini Clubman, Clubman GT, Mini 1100. (locally made.)
73-75, Leyland Mini, Leyland Mini S. (locally made.)
75-78, Leyland Mini, Leyland Mini S. From 76 Leyland Mini SS, LS, From 78 1275LS (locally made with imported motors.)
Hey dude you forgot the Mk1 and Mk2 Matics, again... :roll: :lol:
PostPosted: Mon Nov 29, 2010 6:39 pm
There really is a lot of misinformation in this thread.
Maybe it should start again.
Yes, there are significant differences between UK and OZ cars, but it is not true to say that Australia did not have Mk2 Minis.
The Mini K was officially, in engineering terms, the Mini De Luxe Mk2. The name Mini K was given to the car by the marketing people.
The Cooper S was Mk2 from 1969 to 1971. The Mini Clubman and Leyland Mini ranges were never referred to as Mk1, 2, 3, etc. In terms of the actual physical body, even the last of the Aussie-built Leyland Minis had basically the same body as the Morris 850, with a few changes, including but not limited to, the burst-proof doors, non-protruding door handles, larger taillight clusters, floorpan pressings and, of course, the square nose (aka Clubman front).
The push-button starter continued on the base or fleet model Minis through to the Mini 1100 of 1970. 1971 onwards had the key-start. The Mini De Luxe had key-start, as did the Cooper S, from 1965.
All Australian Minis had external door hinges, but the internal or concealed door hinges were introduced in the UK with the MkIII Riley Elf and Wolseley Hornet in October 1966, the Mini Clubman and 1275GT in 1969 and the ADO20 (Mk3 Mini) also in 1969 (a month later).
There were changes in interior trim and other appointments between the Oz Mk1 and Mk2, but the biggest selling point was the full-synchro gearbox (although there was a bit of a blurring over the change-over). Mini K had 1098cc engine, as did the Mk2 Mini Minor (the Mini 1100), while the Mini De Luxe had 998cc. The Mini Minor had 848cc engine, and later 998cc, but was always listed as Mk1 and stayed as YMA2S2.
The Mk2 Cooper S received a number of cosmetic changes. Note that the Mk1 Cooper S had the same interior trim as the Mini De Luxe, while the Mk2 Cooper S had the same trim as the Mini K. There were also a number of production changes that took place over time, and none are really specific to Mk1 or Mk2 - wipers changed in 1968, for example.
The question asked at the start of this thread was a legitimate one, as there are in fact differences between Mk1 and Mk2, and Australia did have Mk2.
Watto. :shock:
PostPosted: Mon Nov 29, 2010 6:46 pm
Soooo.... the answer to the original question is another question: do you mean aussie or UK MKI/MKII? :wink:
PostPosted: Mon Nov 29, 2010 8:46 pm
So were the early 1969 Oz Coopers with the oval badge and no ID(compliance?) plate near the off-side subframe tower actually Mark 2's or more likely Mark 1 and a halfs? :twisted:
PostPosted: Mon Nov 29, 2010 8:55 pm
Mk1.5 or 1 and a half is just a common term. There is technically no such animal.
The 1969 Minis with no ID plate or compliance plate and the later plastic badge (and it wasn't just Cooper S) were all Mk2.
Watto.
PostPosted: Mon Nov 29, 2010 9:07 pm
they all leaked oil
PostPosted: Tue Nov 30, 2010 7:49 am
Mods rock!
There were no MKII Auto's only MKI early and late.
and the list for MKI & MKII Mokes (and other variants) is even longer.
<EDIT> I posted this list only to show that there were Australian Vehicles produced that were referred to - in offical factory documentaion - as MKII models and the infrence being that those that preceeded are MKI.
PostPosted: Tue Nov 30, 2010 8:22 am
Just to show that not even official factory information is infallible, there are three mistakes that I can see in that identification list above.
Morris Van, should be Morris 850 Van, and the prefix should be YJBAV2. THe R merely means right-hand-drive. The 850 Van was available as YJBAV2R and YJBAV2L (export).
MkII Cooper S should be YG2S4. Even the early 1969 cars I have seen only have YG2S4 stamped into the rad cowl. The K for the Mk1 - YKG2S2 - stood for Morris Cooper. Austin versions (for export only) were YCG2S2 - C being for Austin Cooper. The 997cc and 998cc Cooper was YKA2S1
However, when the Mk2 (or MkII) was released the Morris Cooper designation was removed because all Minis sold in Australia were Morris, and the G designation indicates the engine size - being from 1001cc to 1299cc.
This, of course, brought more confusion than it cleared up, as we don't know if any cars were exported, as the number sequence would have been under the same prefix. There are certainly Mk2 Cooper S currently overseas, but we don't know if any were exported by the factory, or privately. At least with the Mk1 in Austin guise, we can tell if it is a factory export immediately, with the YCG designation. Were Mk2 Cooper S exported? If so, were any badged as Austin? If so, why not the YCG designation?
The 1098cc engine also had the G prefix, so YG2S1 is Mini K, YG2S3 is Mini 1100 and YG2S4 is Cooper S (apparently YG2S2 was not used, as it would have been too easily confused with YKG2S2.
Watto.
PostPosted: Tue Nov 30, 2010 4:16 pm
So, what is this body then?
PostPosted: Tue Nov 30, 2010 4:31 pm
This space for rent
Mini K, same as mine.
PostPosted: Tue Nov 30, 2010 6:45 pm
I beg to differ. Just because you have hard copy doesn't make it gospel.
I have had Mk2 Matics, a 1969 and a 1970. Both had the body prefix YA2S5.
PostPosted: Tue Nov 30, 2010 7:14 pm
Mods rock!
Mmmm.....but that's not on watto's list, so it doesn't exist.
(Hey & no need to shout :wink: )
PostPosted: Tue Nov 30, 2010 7:48 pm
:? What the...?
I didn't post a list, only a few examples.
YMA2S5 is certainly Mk2 (or MkII) Mini-Matic (don't forget the hyphen :lol: ) Released in September 1969.
Although mechanically the same as the Mk1 (YMA2S4) it had the same interior trim, including the three-gauge dash, as the Mini K, but was still only 998cc - I think the compression was a little higher or something as well.
It is a rare beastie, so if anyone has one I can photograph for a feature in TME, please let me know.
Watto. :shock:
PostPosted: Tue Nov 30, 2010 8:23 pm
Watto, there was no YMA2S5, they dropped the M in 1969 when Leyland took over. They are YA2S5.
(Same as they did with the Mk2 S and Mini K). :wink:
C/R on the Matic was 9.0:1, thanks to less dish in the pistons. The head was only the old 12A1456, with same valves and ports as a Deluxe. They also got the HS4 carby like the 1100 auto and 1100S auto had.
The 998 MiniMatic did NOT get the 12G295 head, as the Morris 1100 automatics did. Pity they didn't fit that 1098 motor, it would have given the car some performance.
Last edited by drmini in aust on Tue Nov 30, 2010 8:29 pm, edited 1 time in total.
PostPosted: Tue Nov 30, 2010 8:24 pm
Oh yeah, thanks Doc. :oops:
I stand corrected on that one.
YA2S5 is correct.
Watto.
Users browsing this forum: No registered users and 316 guests
