It is currently Tue Aug 19, 2025 2:17 pm
PostPosted: Mon Dec 06, 2010 10:45 pm
Am I correct in saying that the subframe (twin bolts on each tower) mounts directly to the body with nothing between the body and the subframe?
No rubber or polybushes between body and subframe?
I can't recall what I took off it was so long ago!! :oops:
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Mon Dec 06, 2010 11:21 pm
Some Mini's I have disassembled have had metal plates, others have had none.
I think I put it down to the Leylands having plates rather than Morrises.
But I am also known to be wrong at times.
Someone will put the correct answer up soon! :)
PostPosted: Tue Dec 07, 2010 6:58 am
Mods rock!
The Ozzy Dry Subframes have a spacer about 1/4" thick . In shape it is similar to the lock plate that goes on top of the bulkhead.
I'll try and get a pic up later.
Ozzy wet subframes mounted straight up. The tower top is a completely different pressing. No spacer is used.
The towers on the wet subframes are actually a little taller (about 1/2") than the dry ones.
PostPosted: Tue Dec 07, 2010 7:47 am
Oops! Does that mean I need to look for some spacers.. :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Dec 07, 2010 9:36 am
yep :D
 Post subject: subframe
PostPosted: Tue Dec 07, 2010 9:47 am
Hey...I remember taking them off. Now where did I put them?! :shock:
Regards,
Mike
PostPosted: Tue Dec 07, 2010 9:51 am
They'll be hiding with all the valve caps you've ever lost :lol:
Users browsing this forum: No registered users and 434 guests
