It is currently Tue Jul 22, 2025 7:36 am
 Post subject: very hot coil help
PostPosted: Tue Apr 05, 2005 5:36 pm
my coil is over the top hot, u could fry an egg in seconds on it, i have bought a new coil but would anyone tell me what may have caused the problem, like which side does the distributor wire go to??? just to be sure
sean :D
Potato
PostPosted: Tue Apr 05, 2005 6:19 pm
3 wires go to it i think,, 2 to the negative side from the dissy and tacho if you have one. The other wire goes to positve from the igntion switch. If you leave your ignition ON then you will fry your coil. probably getting hot as its always got power going to it maybe??
1974 Moke - 998cc
PostPosted: Tue Apr 05, 2005 6:51 pm
Additionaly...do you have a Resistor Coil (GT40r) and running a Resistor :idea:
PostPosted: Tue Apr 05, 2005 7:50 pm
if u have fryed your capictor and it earthing out it will get hot too but the car will not start
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Tue Apr 05, 2005 9:42 pm
These only get hot if it's a `resistor' coil (1.5 ohm) and NOT running a resistor.. :wink:
PostPosted: Tue Apr 05, 2005 10:58 pm
Wiring a demo car one time i connected the wires the wrong way around and the coil got superhot real quick. Check your connections.
If it squeaks and leaks, then its sure to be a mini
Building a dream one nap at a time....
http://spaces.msn.com/members/derbydog/
That what I manet Dr....I left out the NOT :lol:
I'll have to read what I type in Future :roll:
Users browsing this forum: Bing [Bot] and 92 guests
