It is currently Tue Aug 19, 2025 6:15 am
 Post subject: High Oil Pressure??
PostPosted: Wed Dec 08, 2010 10:21 pm
Hi,
I fitted a Minispares spring and ball kit to my engine and removed the old plunger and spring. My oil pressure shot up to 90PSI whilst idling, I cut the spring down and it dropped to around 50PSI, though the oil is coming out of the dipstick.
I Know that with the old plunger & spring this never happened.
Any advice as to what I should do??
Thanks Roc
PostPosted: Thu Dec 09, 2010 6:51 am
Roc,
Sounds obvious I know, but put the original plunger & spring back in!
Then things should return to normal, if not then there's another problem in there.
I sounds to me that the ball is getting jammed for some reason, hence the stellar oil pressure.
Why did you replace the plunger? Was it causing trouble? I prefer the plunger type on a roady typically, never had an issue with them.
Jacob
PostPosted: Thu Dec 09, 2010 6:59 am
I prefer the 9/16" ball, it actually seals better at idle and gives you better pressure.
However...
1. You need to cut 2-3mm approx off the spring or the pressure will be higher. Fit the cut end outwards. But 90psi cold is OK, it'll drop to 70-75 when hot.
2. The spring can bend around on the ball and push it sideways off the seat. To prevent this, I put a piece of 5/16" dia steel rod, 40mm long, inside the spring. It's worked fine on the 12 or so motors I've done this to.
PostPosted: Thu Dec 09, 2010 8:16 am
I'm sure this has been covered in a hundred posts, but what should oil pressure be at idle? Mine drops to ~20psi at idle and ~between 50 & 70psi when driving.
2008 Prado GXL
PostPosted: Thu Dec 09, 2010 9:13 am
This space for rent
That's fine Dave, nothing wrong with that. The nearly-10-year-old build in my car currently does about that, 70psi max when cold (or more accurately, not hot) but drops to ~25psi at idle and ~55psi at revs when HOT.
 Post subject: Re: High Oil Pressure??
Rocco wrote:
Hi,
Thanks Roc
You probably have a ball and spring set to traditional factory Cooper S oil pressure. The oil pressure at idle will always be close to 100 when cold, and will drop to more normal idle oil pressures once the oil heats up.
Pressure above idle with this spring combination will always swing towards 100 whilst the oil and engine is in good condition. The spring is now cut down however and won't be able to perform as it was intended.
PostPosted: Thu Dec 09, 2010 9:25 am
Cooper S here never had a ball, from what I can gather. Neither of ours did. They both did have a heavier spring though.
PostPosted: Thu Dec 09, 2010 9:28 am
Thanks doc. Yes, that's what I meant. The ball and spring replacement for the stock set up are set to the same setting as the factory S spring and plunger.
PostPosted: Thu Dec 09, 2010 10:45 am
I don't mind the higher oil pressure, though it is spitting oil through the dipstick and causing a mess to the front of my engine, as well as my driveway??
is there a mod to provide better sealing to the dipstick??
PostPosted: Thu Dec 09, 2010 10:54 am
No matter what your oil pressure, it should not spit oil out the dipstick tube.
Are you sure you haven't done anything else, like overfilled it or blocked off one of the breathers?
PostPosted: Thu Dec 09, 2010 11:13 am
No, all I did was change the spring & ball.
I will re-insert the old spring and plunger and will see what happens.
PostPosted: Thu Dec 09, 2010 8:49 pm
I don't think that is right either. The ones I have bought have included a stock Cooper S spring and ball, which, installed that way (uncut), will produce excessively high oil pressure, as the spring sits "on" the ball and not "in" the plunger. I have always had to shorten the spring, sometimes cutting off 4 - 5 coils to bring the oil pressure back to where it was. I also do Kev's trick of the short rod inside the spring. I do set it up to run no more than 65 - 70 psi hot.
Steve
PostPosted: Thu Dec 09, 2010 8:56 pm
Fair enough. The ones I have picked up I thought behaved the same. I've got another one here I was going to throw it in the new 998 engine.
I'll see how it behaves once fitted.
PostPosted: Fri Dec 10, 2010 2:59 am
Mods rock!
What sort of block have you got (A or A+)?
Done a compression test lately?
