It is currently Wed Aug 06, 2025 10:33 pm
PostPosted: Mon Dec 13, 2010 11:42 am
Mods rock!
The Sprite manifold is 20°, the wrong angle, the carbs will probably hit on the firewall.
The carbs are fine though! :lol:
Grab em, then flog the manifold. Someone here will have a Mini one (30°) cheap that will take the carbs.
The spacer for the float bowls will also need to be changed or modified to suit the new 30° angle
PostPosted: Tue Dec 14, 2010 8:04 pm
Hi guys - rather than open a new thread, and whilst on the topic of carby identification - i looked at the bolt pattern and see that mine is diagonal, so I am thinking 1½"?
Still going through identifying what is actually sitting under the bonnet of my Deluxe.
Cheers, David 8)
Pics:
PostPosted: Tue Dec 14, 2010 8:09 pm
Give Ash some flowers Nick .
This should help everyone out: http://www.ausmini.com/forums/viewtopic.php?t=53394
PostPosted: Tue Dec 14, 2010 8:12 pm
Thanks :oops:
HS4 it is....
PostPosted: Tue Dec 14, 2010 8:13 pm
Cheers, David 8)
Pics:
Yes FatTyred, it is a 1½" HS4 SU.
Looks like one from a 76 to 78 Leyland Mini (or S or LS)
PostPosted: Tue Dec 14, 2010 8:16 pm
Cheers. It's quite difficult buying a 45 year old car which has little history of work done and working out what all of it is!
At least knowing that, and wanting to stick with the 998 - I have a starting point for go-fast(er) bits.
Dave 8)
PostPosted: Tue Dec 14, 2010 8:18 pm
Dave 8)
The HS4 is a good choice for a 998. :wink:
PostPosted: Tue Dec 14, 2010 8:22 pm
It just needs help breathing!
Was thinking of starting with extractors, inlet manifold, filter upgrades (along the lines of the Minisport Stage 1 Tuning Kit or similar) and a damn good service!
PostPosted: Tue Dec 14, 2010 8:24 pm
Dave 8)
...or an 850 even. In UK the automatic 850s got an HS4- it's worth a couple of HP on any motor over an HS2.
The 1098 autos (in Morris 1100) also got an HS4 instead of HS2.
PostPosted: Tue Dec 14, 2010 8:30 pm
If you tell me the letters/numbers on the float bowl tag I can tell you what vehicle this came off.
