It is currently Fri Jun 27, 2025 7:14 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Dec 15, 2010 5:29 pm
There have been some very good V4s in this world, and also some very bad ones. That Ford V4 was the latter. :lol:
I can't think of any good ones. The closet would be the narrow angle Lancia.
PostPosted: Thu Dec 16, 2010 6:55 am
Yep I was thinking of the Lancia, also some of Honda's V4 bikes.
Also OMC's 90° V4 outboards, those things run smooth as silk.
PostPosted: Thu Dec 16, 2010 7:00 pm
Why is a V4 "rough" :?: I'd assume when their designed (like any other V engine) they would be built to be smooth as possible...why is a V6 smooth and not a V4 :?:
PostPosted: Thu Dec 16, 2010 7:13 pm
A V6 is not smooth. Especially a 90° like a Holden/Buick motor. Look at the soft engine mounts that are needed to soften the vibrations that the balance shaft can't even fix. Look at the crank throws and the spacing of the firing of a 90° V6 and you will see why they are so bad.
If you want smooth you need a V8 or an inline 6.
PostPosted: Fri Dec 17, 2010 6:14 am
It depends on the engine. A V4 with a balance shaft can be nicer than an inline 4, likewise a V6. Inline fours can have higher frequency vibration which is more annoying than a lower rev 'rumble'. Honda Goldwings have opposed sixes and nearly no vibration.
Anyway, the original point was to have some Harley rocker covers rumbling nicely in a cutaway mini bonnet. Harley couldn't make their motors smooth so they rely on a very clever 'solid' and rubber mounting system which transmits enough rumble to give it 'character' but not enough to vibrate the bike to bits.
Ultimately, the smoothest motors would be opposed or V12s, but it's chasing your tail to some extent. Other factors such as size come into play. The reason I originally mentioned HD motors was they're the last of the pre-unit construction, i.e. separate gearbox and motor, assemblies which would work with a transaxle. The more I think about this, the more I like it. There's a Volvo 440 transaxle for sale locally and my Mk II doesn't have an engine yet...
PostPosted: Sat Dec 18, 2010 5:36 pm
A Commodore seems pretty smooth to me, pop the bonnet and watch it at idle or even at 6000rpm and it just sits their :?
PostPosted: Sat Dec 18, 2010 8:19 pm
better than the bug catcher i saw today on the side of the road, it had a hidden speed camera in it, sitting on a older EB ford falcon
